[SOLVED] Wave Color Keyboard Shortcut
Questions, discussion and recipes for scripting and batch processing in Audacity.
See also the "Scripting" section of the Audacity manual.
sagetyrtle
Post by sagetyrtle » Tue Aug 27, 2019 1:22 pm
I'd love to have the ability to assign a keyboard shortcut to Wave Color. Ideally I'd be have one for:
instrument 1
instrument 2
instrument 3
instrument 4
Re: Wave Color Keyboard Shortcut
Post by steve » Tue Aug 27, 2019 1:30 pm
Create a Macro to set the colour (https://manual.audacityteam.org/man/macros.html)
then assign a keyboard shortcut to run the Macro (https://manual.audacityteam.org/man/key ... ences.html)
sagetyrtle
Post by sagetyrtle » Wed Aug 28, 2019 12:35 pm
Oh, fantastic! I didn't realize this was a possibility. Thanks, Steve.
sagetyrtle
Post by sagetyrtle » Wed Aug 28, 2019 1:22 pm
Hmm, I'm stymied. Here's what I've done so far (Audacity 2.2.1):
File | Chains | Edit Chains | Add | Insert
This window pops up:
https://imgur.com/Pey9qxe
But none of these commands are Track Menu or Wave Color or Instrument 1. I'm not sure what my next step should be. Any suggestions?
Post by steve » Wed Aug 28, 2019 1:39 pm
Here's the Scripting reference documentation in the Audacity manual: https://manual.audacityteam.org/man/scr ... rence.html
If you search that page for "color" (American spelling), you will find the command: "Set Track Visuals..."
sagetyrtle
Post by sagetyrtle » Wed Aug 28, 2019 8:48 pm
Hi Steve - I'm still floundering. I found the command Set Track Visuals, but I'm not able to see the connection between:
And "SetTrackVisuals" or "enum Color".
Basically I've got the cake ingredients and I can see the cake all ready to eat, but the in-between part is escaping me...
Post by steve » Thu Aug 29, 2019 10:54 am
You can select one of the 4 preset colours:
sagetyrtle
Post by sagetyrtle » Thu Aug 29, 2019 8:57 pm
I know the answer must be obvious, I really am trying to understand.
Once I've gotten to:
What is the very next step?
Post by steve » Thu Aug 29, 2019 9:46 pm
Your version of Audacity is too old. You need Audacity 2.3.2. You can get it via the Audacity website: https://www.audacityteam.org/download/
In Audacity 2.3.2, the old "Chains" feature has been renamed "Macros", and Macros can do a lot of things that Chains couldn't.
How to use Macros: https://manual.audacityteam.org/man/macros.html
sagetyrtle
Post by sagetyrtle » Fri Aug 30, 2019 9:03 pm
Aha! Thanks, Steve. That was the missing piece. For anyone else who comes across this post, here's the step-by-step:
Audacity 2.3.2
CREATE MACRO:
Tools | Macros | New
enter name of macro [for example: red]
with name selected, click Insert
under Choose Command, choose Set Track Visuals
upper right hand corner, click Edit Parameters
third box down: Color - check the box, choose your color [I chose 1, for red]
SET KEYBOARD SHORTCUT:
Edit | Preferences | Keyboard
Key bindings: Tree
scroll down to Apply Macro
choose your new macro name
set keyboard shortcut, click Set, then OK
You should be all set.
