Hi All
is it possible to alter the output file following a batch chain run? is there a command available for this in the chain builder?
like a rename command?
Thanks
Steve
Renaming Files in Chains (Macros)
Re: Renaming Files in Chains (Macros)
No there isn't. The Macro commands are specifically for Audacity. If you want to script operating system commands, you need to use a more comprehensive scripting language (such as Python).
Datman, I use A Better Finder Rename. It is awesome and you can rename (or amend) files using many parameters in the file... Plus, you can create droplets. Highly recommended!
Datman wrote: ↑Wed Jun 19, 2019 7:36 am
Thanks for the info...just had a short look, looks like a tool for much more....there is a free trial version which i may download. Cheers
