Help Updating
Bug reports for Audacity 2.3.1 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
Vitrushka
Help Updating
Post by Vitrushka » Tue Feb 20, 2018 9:23 pm
I installed the update, but I'm not sure if I'm supposed to save it over the old version, or as a new file itself? If I delete the old version, will I lose anything? I've never done an update before, so I'm pretty clueless. :?
Re: Help Updating
Post by steve » Wed Feb 21, 2018 10:27 am
If you are updating a previous version 2.x, you should be able to just install over the top of the previous version, though that may give you a double entry in the Windows Control Panel "Software" section. My recommendation would be to uninstall the old version first.
If you are upgrading a version older than 2.0, you should definitely uninstall the old version first.
Upgrading "should not" lose anything, though as always, best practice is to keep backups of anything important.
