Manage Macros
Feedback and bug reports for Audacity 3.0.3 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
Re: Manage Macros
Post by steve » Mon Mar 15, 2021 5:17 pm
My suggestion:
Add a "Save" button in the left column. When pressed, any changes are saved and you will not be nagged to save changes.
Change the "Cancel" button to "Close". If there are unsaved changes you will be prompted to save changes before the dialog closes.
waxcylinder
Re: Manage Macros
Post by waxcylinder » Mon Mar 15, 2021 5:20 pm
My suggestion:
It would surely be better on the right as you are Saving the editing that you are doing on that current focused Macro - the Save is the final part of the editing.
Sounds sensible - since, as you say, Cancel doe not do "what it says on the tin"
Peter.
Re: Manage Macros
Post by steve » Mon Mar 15, 2021 5:32 pm
I considered that, and there's more space for it on that side, but looking at the buttons in the left column and what they do:
  • New => make a new macro
  • Remove => remove / delete the selected macro
  • Rename => rename the selected macro
  • Restore => restore (back to default) the selected macro
  • Import => import a macro
  • Export => export the selected macro
  • Save => save changes to the selected macro
If there have been no changes, the "Save" button would be greyed out.
The left column are all about "macros", whereas the right column are about "commands". It is the selected macro that is being saved, not the selected command.
waxcylinder
Re: Manage Macros
Post by waxcylinder » Mon Mar 15, 2021 5:37 pm
I suspect this will be a case of our Audacity Mantra "Doer decides" ;)
And I suspect that is likely to be James as "Mr. Macros" :ugeek:
Peter.
FL Coast
Re: Manage Macros
Post by FL Coast » Mon Mar 15, 2021 5:40 pm
My suggestion:
Peter.
That makes more sense to me too.
billw58
Re: Manage Macros
Post by billw58 » Mon Mar 15, 2021 6:40 pm
That may be technically correct, but to the user it looks like they are editing a macro by adding / removing / changing commands.
Thus I'd put the Save and Cancel buttons under the "Edit Steps" box.
-- Bill
Re: Manage Macros
Post by steve » Mon Mar 15, 2021 6:48 pm
Whether left or right column (I could live with either), I think adding a "Save" button and renaming "Cancel" as "Close" would be a big improvement.
If we're all in agreement, I'll add this as a proposed solution in the bug tracker.
mafg1953
Re: Manage Macros
Post by mafg1953 » Mon Mar 15, 2021 8:50 pm
Thanks - even though it didn't affect the macros themselves, this will be a welcome change.
waxcylinder
Re: Manage Macros
Post by waxcylinder » Tue Mar 23, 2021 2:42 pm
This has been fixed for the upcoming 3.0.1 release.
1) The Cancel Button is replace with a Close button
2) The Close button does what you would expect it to
3) A new save button has been added to enable you to Save edits to a Macro
I think this now looks, and works, a lot better.
Peter
mafg1953
Re: Manage Macros
Post by mafg1953 » Tue Mar 23, 2021 3:45 pm
Peter
Cool - thanks! So when your profile says you're retired, I'm assuming that doesn't refer to this audio stuff - you seem pretty full time to me!
Mike
