Manage Macros
Feedback and bug reports for Audacity 3.0.3 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
FL Coast
Manage Macros
Post by FL Coast » Mon Mar 15, 2021 4:01 pm
Audacity 3.0.0rc06
Under the Manage Macros, if you edit a macro, there is no "OK" button to initiate the save. Must hit the X button, then click OK.
Re: Manage Macros
Post by steve » Mon Mar 15, 2021 4:06 pm
Under the Manage Macros, ... there is no "OK" button
Same here on Linux.
Thanks for reporting this.
Re: Manage Macros
Post by steve » Mon Mar 15, 2021 4:10 pm
Apparently this is intentional :?
From the Audacity bug tracker:
Bug 2524 - Macros "OK" button is confusing - doesn't do "what it says on the tin"
Comment #3
OK button does much the same as cancel, so I removed it.
  • OnCancel prompts you if there has been a change.
  • OnOK saves without prompting.
That difference is too slight to merit a button, and with the OK
button present, people might/do reasonably expect the dialog to apply the macro too.
I also improved positioning of these buttons, and fixed a case where cancel did not appear from the dialog to actually cancel your edits (even though it actually did).
Those steps were:
- Edit a macro
- Cancel Macro dialog
- Say 'no' to save changes.
- Reopen Macro dialog
Observe:
A: Changes appeared to have been made, despite saying 'no'.
Personally I think this is still confusing, and I assume that you also find it unclear as you raised the issue here, so I'm inclined to reopen the bug.
Do you think it would be less confusing if the button was labelled "Close" rather than "Cancel"?
FL Coast
Re: Manage Macros
Post by FL Coast » Mon Mar 15, 2021 4:37 pm
Agreed. By having only "Cancel" I was not pressing that button in fear of loosing the changes to the Macro I just Edited. Even Close is still confusing.
Maybe, Save with no other dialog and Cancel with (or without) a dialog box Exit without saving, YES or NO.
FL Coast
Re: Manage Macros
Post by FL Coast » Mon Mar 15, 2021 4:45 pm
If that is not acceptable, Then maybe the single button that reads Save/Cancel. That might be more doable and less confusing.
FL Coast
Re: Manage Macros
Post by FL Coast » Mon Mar 15, 2021 4:52 pm
or maybe the simplest would just be............
EXIT
at least that still leaves me with a feeling I still have options if I hit this button.
billw58
Re: Manage Macros
Post by billw58 » Mon Mar 15, 2021 4:53 pm
My quick-take on this is to rename the "Cancel" button to "Close", but to add "Save" and "Cancel" buttons that become active when a macro is created or edited. So "Cancel" reverts the changes to a macro, or deletes an unsaved (new) macro. Should it ask for confirmation? Or is this getting too busy/complicated?
Doesn't "Cancel" (as currently displayed) mean revert everything? Wouldn't this mean reverting all changes made to macros including new ones?
"Cancel" makes sense when the window is "shrunk" and is the "Macros Palette" ("Cancel" means "don't apply a macro"), but makes less sense when the window is "expanded" and is the "Manage Macros" dialog. For consistency with the two versions of the dialog perhaps this button should always be labelled "Close".
Playing with this I've found what may be an inconsistency.
Open or create a project with some audio in it.
1) Edit an existing macro, changing one or more steps in the macro
2) Click on a different macro in the left panel
- you get a "Save changes" dialog
2) Click the Apply Macro to "Project" button
- the changes are saved (without confirmation dialog) and the macro is applied
In any case, what we have works, so I don't think I'd want to hold up 3.0.0 for this.
-- Bill
waxcylinder
Re: Manage Macros
Post by waxcylinder » Mon Mar 15, 2021 4:56 pm
Audacity 3.0.0rc06
Or just do something else in the Macro Manager
a) shift to a different Macro
b) Hit the New button for a new macro
c) Import or Export
d) or just Run the macro
But yes, an "OK" button in the right hand button set could be a good idea.
I've written a fair number of Macros - mainly for QA speed testing - and I've never felt the need for an "OK" button
Peter.
waxcylinder
Re: Manage Macros
Post by waxcylinder » Mon Mar 15, 2021 4:58 pm
Cancel provokes a dialog asking if you want to save the changes or not.
Peter.
Re: Manage Macros
Post by steve » Mon Mar 15, 2021 5:05 pm
By convention, "Cancel" means "revert changes and close the dialog", which is what both I and FL Coast assumed that it meant:
" By having only "Cancel" I was not pressing that button in fear of loosing the changes to the Macro I just Edited."
