didn't work with the microphone wireless hands free B19
Feedback and bug reports for Audacity 3.0.3 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
win22n
Post by win22n » Sun Mar 14, 2021 1:01 pm
the speakers of B19 has played the sound, while the microphone didn't pickedup the recording.
my settings are MME/HEADSET B19 /MONO/HEADSET B19
i didn't get the "Error opening sound device ..." message.
while i set the windows direct sound and WASAPI, I got it.
1. the recording from the internal microphone is works.
2.the same problem was in version 2.3
deviceinfo.txt
(10.87 KiB) Downloaded 13 times
2021-03-14 15_11_36-Audacity (Recovered).png (18.05 KiB) Viewed 247 times
Audacity_dbgrpt-7056-20210314T155536.zip
(9.98 KiB) Downloaded 11 times
Re: didn't work with the microphone wireless hands free B19
Post by steve » Sun Mar 14, 2021 3:11 pm
Bluetooth devices can be problematic for Audacity due to connectivity issues beyond our control. Also, given that bluetooth uses compressed audio data, the sound quality is reduced during transmission.
If your headset has an "always on" option, then you may have more success with it.
