Default entry setting in Amplify
Feedback and bug reports for Audacity 3.0.3 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
mafg1953
Re: Default entry setting in Amplify
Post by mafg1953 » Tue Mar 02, 2021 12:02 am
mafg1953 wrote:
Mon Mar 01, 2021 11:52 pm
I pushed an audio file over -0dB in another program.
I then pushed a file over -0dB in Audacity and exported and then opened it as a new file and I was able to get an adjustment suggestion using the Amplify Effect. Maybe the way that clipped files are stored is different in a file generated by Audacity vs. other programs. Maybe Audacity files keep actual dB level in clipped files while other programs don't.
Mike
ChrisSW
Post by ChrisSW » Tue Mar 02, 2021 12:08 am
Ah - thanks Mike - that would explain why some of the WAV files offered the negative amplification and this doesn't. Many thanks for your prompt response. I use the program most days during the lockdown and it's. stoning piece of work. Well done to all concerned.
Post by steve » Tue Mar 02, 2021 1:04 am
Audacity uses "32-bit float PCM" format internally. This format has benefits of not only great sound quality, but also the ability to support audio above 0dB.
Most WAV files are "16 or 24 bit integer PCM", which cannot go over 0dB (anything over 0 dB is simply clipped off).
