Spectogram View Scale changes when I use Punch/Paste
Feedback and bug reports for Audacity 3.0.3 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
mafg1953
Post by mafg1953 » Fri Feb 26, 2021 1:05 am
Hi,
I've been testing out version 3.0.0 and it is working quite well - thanks for all the work you put into it.
I did come across an issue when using Spectogram view and Punch/Paste. I do editing with either Spectogram view or Multi-View turned on with a Logarithmic range of 60Hz to 10000Hz. If I use the effect Punch/Paste, the Spectogram scale changes to 1 to 22,050. The edit gets done properly, but I lose the perspective on the waveform as I definitely don't need that wide of a range. In V 2.4.2, that does not happen.
Thanks,
Mike
mafg1953
Re: Spectogram View Scale changes when I use Punch/Paste
Post by mafg1953 » Fri Feb 26, 2021 1:19 am
Hi again,
The same thing happens if I highlight some audio and use the Generate>Silence feature.
Mike
billw58
Post by billw58 » Fri Feb 26, 2021 1:59 am
I can't reproduce this with 3.0.0rc03 (Feb 24) on a 2019 iMac with macOS 10.15.7. I don't have the punch/paste plug-in installed but when I generate silence into a track in spectrogram view the spectrogram settings don't change.
In the track spectrogram settings is "Use Preferences" checked? Are your track spectrogram settings different from Spectrograms Preferences?
-- Bill
mafg1953
Post by mafg1953 » Fri Feb 26, 2021 2:13 am
Hi Bill,
Below is a screenshot of my global preferences, the track preferences, and a .gif of the change in scale when I generate silence:
Edit > Preferences
Track Preferences
Insert Silence
waxcylinder
Post by waxcylinder » Fri Feb 26, 2021 10:44 am
I can't reproduce this on W10 with 3.0.0 RC03
Peter.
Post by steve » Fri Feb 26, 2021 11:06 am
I can't reproduce this issue on Linux with 3.0.0 rc03, but I do occasionally see that there's something peculiar happening.
Which exact version?
James Crook
Post by James Crook » Fri Feb 26, 2021 11:36 am
I can't reproduce this either.
Are the settings changed after this happens? I.e. does something cause the settings to change, or is Audacity drawing to the wrong settings?
Can you make a more minimal example?
- e.g. can sync-lock be off, and just one track?
- is multi-view necessary for this to happen, or can it happen with just a spectrogram?
Thanks!
mafg1953
Post by mafg1953 » Fri Feb 26, 2021 12:12 pm
Hi,
I'm using Win 10 and V 3.0.0 rc 03.
I'm going to reset my preferences and try it again to see if that helps and what I might have done to get this to happen. If I run the "same" preferences on V 2.4.2, it works fine.
Mike
Post by steve » Fri Feb 26, 2021 12:19 pm
If it's not too late, make a backup copy of your preference files before resetting.
mafg1953
Post by mafg1953 » Fri Feb 26, 2021 12:40 pm
Thanks for the reminder Steve - I did make a backup - lesson learned many many times!
It looks like the issue is that I had checked "Use half-wave display when collapsed" thinking it would save desktop space (but it doesn't). I unchecked it, and the issue with the resetting of the scale does not happen. I re-checked it and the issue does happen.
I also checked V 2.4.2 and the same issue arises when "Use half-wave display when collapsed" is checked.
Thanks for the feedback.
Mike
