Convert .aup to .aup3
Feedback and bug reports for Audacity 3.0.3 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
BenAndo
Re: Convert .aup to .aup3
Post by BenAndo » Wed Feb 24, 2021 5:25 am
I may be mistaken but it looks as though you can download an exe of Audacity 3.0.0rc02 here: https://www.fosshub.com/Audacity-devel.html
I downloaded the Windows Zip file and sure enough it's Audacity 3.0.0 :) I was pleased to see another feature where you can easily import and export macros. Well done Audacity team!
waxcylinder
Post by waxcylinder » Wed Feb 24, 2021 8:34 am
These Release Candidates are for testing purposes only - they should NOT be used for production work.
For example we found a serious bug in RC02 which necessitated a further release candidate RC03 (not yet built).
If you do test them, we would appreciate feedback.
Yes that's a useful addition to the toolkit.
Peter
mafg1953
Post by mafg1953 » Wed Feb 24, 2021 2:04 pm
Peter
Nice - if we want to tinker with it, is there a list of changes available that were added/adjusted since 2.4.2 that we could use to test-out the new version?
Mike
Never mind - I found the list in the link to the Help.Zip :D
Mike
waxcylinder
Post by waxcylinder » Wed Feb 24, 2021 3:47 pm
Mike,
the alpha 3.0.0 Manual has a Wat's New section: https://alphamanual.audacityteam.org/ma ... is_release
Peter
mafg1953
Post by mafg1953 » Wed Feb 24, 2021 6:41 pm
Thanks Peter - do you know what the difference is between "Audacity devel Windows Installer 28MB" and "Audacity devel Windows Installer 11.9MB"?
I'll be trying the updated options along with all my Macro's and .VST plugins in the new version over the next few days and let you know if anything funny crops up.
Thanks for all the improvements in the software - I'm sure it's like a full-time job!
James Crook
Post by James Crook » Wed Feb 24, 2021 7:03 pm
Thanks! The smaller one was meant to be labelled as Windows Zip. It is now.
waxcylinder
Post by waxcylinder » Wed Feb 24, 2021 8:00 pm
The main reason for the Zip being smaller is that it doesn't contain the Manual.
Peter.
