Convert .aup to .aup3
Feedback and bug reports for Audacity 3.0.3 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
ksyrx
Operating System: Linux Debian
Post by ksyrx » Sat Jul 11, 2020 2:54 pm
Thanks you so much for Audacity! It's great program. And, version 3.0.0 seems cute.
I suppose this only my problem... But, may be anybody will help me here... I've more .aup projects, which can't be opened in newest Audacity version (because it uses .aup3 format). Can I convert .aup to .aup3? If not, then OK - I'll revert to Audacity 2.x.x and deal with my projects perfectly. I just want ask you (developers of Audacity): "Are there ways to convert .aup to .aup3 without much time consuming?".
Thanks you.
Re: Convert .aup to .aup3
Post by steve » Sat Jul 11, 2020 2:58 pm
Audacity 3.0.0 is in early alpha stage of development. It should NOT be used for production work.
The ability to read AUP projects will be added before release, but the code for that hasn't been written yet.
waxcylinder
Post by waxcylinder » Sat Jul 11, 2020 3:59 pm
As Steve says ...
and be aware that as the development project progesses the nature of the aup3 files is subject ti change abd that means that earlier created .aup3 projects cannot be opened in later alpha versions of 3.0.0.
This has occurred at least twice now recently and is quite likely to do so agian in the future until the developers finalize the design of the database schema.
mafg1953
Post by mafg1953 » Wed Jul 15, 2020 3:34 pm
Is there a download link to the 3.0.0 alpha version so we can mess around with it?
Post by steve » Wed Jul 15, 2020 3:47 pm
Only the source code at the moment: https://github.com/audacity/audacity
Binaries (executables) will be made available later in the release cycle.
mafg1953
Post by mafg1953 » Thu Oct 01, 2020 12:37 pm
Hi Steve,
Not trying to nag, but is there any update on the alpha executables or a release date for 3.0?
Thanks
Mike
Post by steve » Thu Oct 01, 2020 12:44 pm
Very provisional release date is November, but this depends on the satisfactory fixing of all serious bugs and no new problems.
This release cycle was always expected to be a long one as AUP3 is a very substantial change.
mafg1953
Post by mafg1953 » Thu Oct 01, 2020 1:17 pm
Thanks!
mafg1953
Post by mafg1953 » Wed Jan 06, 2021 6:24 pm
Hi Steve, just checking on a status update of Ver 3.0 and also maybe an executable alpha version? Thanks.
Post by steve » Wed Jan 06, 2021 6:46 pm
As you've probably guessed, there were some problems, and then we hit Christmas. Work has resumed and good progress has been made. All known "P1" bugs are now fixed, though work continues on other important issues. I don't yet have a revised release date - my guess would be some time in February, but take that with a large pinch of salt ;)
