GUI bug: Localized Audacity loses some access keys
Bug reports for Audacity 2.3.1 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
Phroneris
Operating System: Windows 7
Post by Phroneris » Thu Nov 29, 2018 7:37 pm
I'm translating Audacity to Japanese.
This problem isn't so usual nor fatal, but I'm glad if this minor inconvenience is fixed.
Though I don't know how about other languages, at least in Japanese, access key is placed at the end of main string in upper case and enclosed in parentheses.
Code: Select all
[EN]: Effe&ct
[JP]: エフェクト(&C)
The problem is that there are some cases where the access key with parentheses becomes invisible and only the main string is shown.
For example, when importing an audio file, three options (two radio buttons and one checkbox) appear in a warning dialog and each of them has its access key.
However, Audacity visually displays them as if they don't have their access keys at the end.
Code: Select all
[EN        ]: Make a &copy of the files before editing (safer)
[JP(ja.po) ]: 編集前にファイルのコピーを作成する (安全) (&C)
[JP(visual)]: 編集前にファイルのコピーを作成する (安全)
Red is the exemplified string and blues are the others with the same problem.
Another example can be seen on [Edit] > [Preferences] > [Recording] > [Name newly recorded tracks].
Four checkbox options lack their access keys visually.
Code: Select all
[EN        ]: Custom Track &Name
[JP(ja.po) ]: カスタムトラック名(&N)
[JP(visual)]: カスタムトラック名
Note that the hidden access keys are just hidden and they do work.
In the second case above, pressing Alt+N toggles the custom track name successfully.
Thanks.
OS: Windows 7 64bit
my ja.po: https://github.com/Phroneris/audacity/b ... cale/ja.po
Audacity version: 2.3.1-alpha-Nov 24 2018 (built by myself at commit 800ddae34b424a377ef4bbac16aac7638f93ad1b)
Re: GUI bug: Localized Audacity loses some access keys
Post by steve » Thu Nov 29, 2018 8:21 pm
On Linux, these access keys only show when the Alt key is pressed.
This is what it looks like for me (English):
Note that it is the character preceded by the "&" that is underscored.
How can that work if the localized text does not have the relevant character?
Phroneris
Post by Phroneris » Fri Nov 30, 2018 10:45 am
Then I tried three patterns.
Code: Select all
no "&"  : 編集前にファイルのコピーを作成する (安全) (C)
no char : 元ファイルから直接読み込む (高速) (&)
no ")"  : 次回からは表示せず、いつも上記設定を使用する(&W
Result: all are visible.
Post by steve » Fri Nov 30, 2018 12:17 pm
I think you would do better asking about this on the translator's mailing list, as that is where the translation experts hang out. (https://sourceforge.net/projects/audaci ... ranslation)
Phroneris
Post by Phroneris » Fri Nov 30, 2018 1:51 pm
OK, thanks.
