22050Hz files corrupt others?
Bug reports for Audacity 2.3.1 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
Re: 22050Hz files corrupt others?
Post by steve » Sun Nov 04, 2018 10:16 pm
SoloMael wrote:
Sun Nov 04, 2018 10:02 pm
then change the project rate at the bottom left.
Change it to what?
If I change it to a low number (for example, 4410) then it sounds very muffled, as expected.
If I change it to a number bigger than 22050 (for example, 44100) then it sounds exactly the same as when I first imported it (also as expected).
SoloMael
Post by SoloMael » Sun Nov 04, 2018 10:19 pm
Are you certain? I retried it once more and I'm still getting the distracting compression.
Can you try again and listen closer?
Post by steve » Sun Nov 04, 2018 10:27 pm
How does this version sound to you?
https://www.sendspace.com/file/3uknx2
SoloMael
Post by SoloMael » Sun Nov 04, 2018 10:47 pm
You're right, it sounds untouched...
I don't know what I have to do to achieve that result though... I literally just reinstalled Audacity days ago and didn't mess with the settings, so that can't help....
Post by steve » Sun Nov 04, 2018 11:54 pm
Try this:
  1. Import one of the 22050 Hz WAV files into a new Audacity Project.
  2. Change the Project Rate (lower left corner of the main Audacity window) to 44100
  3. Click on the track to ensure it is selected
  4. "Tracks menu > Resample"
  5. Set the "new sample rate" to 44100, and click "OK"
  6. Play the track.
How does it sound?
SoloMael
Post by SoloMael » Mon Nov 05, 2018 12:22 am
It worked, thank you very much!
Post by steve » Mon Nov 05, 2018 12:48 am
My guess is that the problem was due to your sound card, or sound card drivers. At least you've got a good workaround :)
