22050Hz files corrupt others?
Bug reports for Audacity 2.3.1 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
SoloMael
Post by SoloMael » Fri Nov 02, 2018 2:19 pm
I'm currently working on layering multiple songs together, and I have 2 sets of lossless files I'm combining: .wav files encoded at 22050Hz and .flac files encoded at 44100Hz.
For some reason, whenever I import both of them into the same project, the second one I import has vastly decreased audio quality. I suspect this is tied to the aforementioned wav files, but I'm not 100% sure.
I've tried to do everything different, including exporting the files to check if it was just the preview, and changing the file type and stuff.
Is there any workaround I can try for now? I'd like to get this project done soon.
Re: 22050Hz files corrupt others?
Post by steve » Fri Nov 02, 2018 2:48 pm
When importing an audio file into an empty project, Audacity takes the sample rate from the imported file as the sample rate for the entire project. Thus, if the first file that you import is one of the 22050 Hz WAVs, then Audacity will set the "Project Rate" to 22050. This will lower the sound quality of the 44100 Hz tracks.
To solve the problem, you need to manually change the Project Rate back to 44100. The Project Rate is in the bottom left corner of the main Audacity window.
SoloMael
Post by SoloMael » Fri Nov 02, 2018 3:09 pm
I tried it, all it does is change the 22050 to sound compressed and muffled just like before...
SoloMael
Post by SoloMael » Sat Nov 03, 2018 2:21 pm
Can someone please help me?
Post by steve » Sat Nov 03, 2018 3:54 pm
So are you saying that if you import the 22050 Hz WAV file into an empty project, it sounds OK, but if you import it into a project containing other tracks it sounds muffled?
Do you mean "distorted" rather than "muffled"?
SoloMael
Post by SoloMael » Sat Nov 03, 2018 7:29 pm
I guess I mean "distorted", but it's more like severe compression.
And if I import it into an empty project and increase the sample rate, it has the same issue, no matter what I change it to.
Which happens automatically when I import something with a higher sample rate.
Post by steve » Sun Nov 04, 2018 4:26 pm
How big are these WAV files?
SoloMael
Post by SoloMael » Sun Nov 04, 2018 9:22 pm
Ranging from 0.3 MB to 11 MB.
Post by steve » Sun Nov 04, 2018 9:39 pm
Could you upload the smallest one to a file sharing service such as dropbox or sendspace (ensure that it is public and does not require registration), then post exact step-by-step instructions for how I can reproduce the issue.
SoloMael
Post by SoloMael » Sun Nov 04, 2018 10:02 pm
https://www.dropbox.com/s/loi40q8dkbsaf ... p.wav?dl=0
Just import this wav file into a new project, then change the project rate at the bottom left.
