Hi,
With latest git master version, I got a segfault (SIGSEGV).
I use Debian sid, linux 4.18
I load a wav file (from a Zoom H6 recorder).
It loads the file and just at the end of the loading process, before removing DC offset and Normalizing, it crashed.
I’ve done a bt in gdb and a git bisect.
The git bisect says:
511b810fdcb6bb418e915dc4295661c49dec3ec4 is the first bad commit
Thanks for the report, and for taking the trouble to debug.
The Audacity 2.3.0 tarball is, or will be marked as “experimental” as we are now aware that we have some problems with it.
We are planning a short release cycle for 2.3.1 which is focussed on stability, so I’ll log this, and pass the information that you gave on to the developers.
I suspect there is more than one crash bug happening here, and that it may not be deterministic, so your bisection may not be correct.
First, you should know that one known crash in Linux was lately fixed with this commit:
a17af37c1ef9a4611add492d8ba02d1dfb270210
So if you try to bisect again, I suggest you cherry-pick that commit each time, to eliminate the known problem.
Secondly, the commit you reported as the first bad one is in fact a merge commit. The difference between it and one of its two parent commits is empty.
Therefore, a correct bisection of a DETERMINISTIC bug would not have identified that commit. But perhaps this isn’t deterministic. So, if you repeat the
bisection, I suggest you try to let the crash happen a few times.
Finally, please identify the commit you built when you generate a crash report.
The stack trace you gave mentions std::function, and many uses of that are new in 2.3.1 development, but were not present in the commit you identified
as the first bad commit. This makes me think there is more than one bug. If there really is some crash reliably reproducible at commit 511b810fdcb6bb418e915dc4295661c49dec3ec4, it may be a different bug and a different stack track for that will tell us something.
I just (tried to) rebuilt 511b810fdcb6bb418e915dc4295661c49dec3ec4
But:
1 - I cannot cherry pick a17af37c1ef9a4611add492d8ba02d1dfb270210 on it
2 - There is a compile error (see attached file)
