Run with no gui
Bug reports for Audacity 2.3.1 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
socialmediamaster
Probationer
Run with no gui
Post by socialmediamaster » Fri Aug 31, 2018 6:15 pm
Is it possible to run the program without any gui? Like if i'm running the program on ubuntu server.
That would be really awesome. So you could just input a mic and then record without the gui present.
Then you could also start the program with ssh connection and record from a distance.
Best regards
Peter Storm
[Advert removed by moderator]
Re: Run with no gui
Post by steve » Fri Aug 31, 2018 7:12 pm
Audacity is not suitable for running on a server. It is heavily GUI oriented and it is not security hardened for server use.
SoX is a command line audio editor that may be more suitable: http://sox.sourceforge.net/
