Hebrew UI has too agressive justifiaction to the right
Bug reports for Audacity 2.3.1 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
zohar_ml
Post by zohar_ml » Thu Aug 02, 2018 8:39 pm
Hello,
After setting the UI of the program to Hebrew each new session / new project ALL the justification of the UI changes to RTL, this includes many places that should not be justified RTL (but keep LTR)
examples of wrongly RTL:
1) the splash screen starts with a totally flipped text (attached)
2) the main screen has the all the sound samples rotated to the right, and even the time numbers in this part are flipped. (attached)
3) All order of the icons on the top bars are flipped.
4) Under edit -> pref -> interface, all the drop-down boxes are hidden! (attached)
It is totally impossible to work on the program with this flipped UI!
If I start the program with the interface language set to English and then change it to Hebrew, the interface is good: all the UI is still LRT and only the text in the menus changes to Hebrew (attached)
This is the correct way the UI should be, and now the program is usable.
The problem is if I close and open the program or press Ctrl+N the UI flips again to it’s wrong way.
I would be happy to help you fix this.
Tested on V2.3 (and 2.2.2) on windows 10 64bit
Zohar
You do not have the required permissions to view the files attached to this post.
אריה ענק משער האריות
Re: Hebrew UI has too agressive justifiaction to the right
Post by אריה ענק משער האריות » Tue Aug 07, 2018 4:41 pm
The previous version is fine
Post by steve » Tue Aug 07, 2018 6:09 pm
Which version is fine?
Which platform? (Windows, Mac or Linux)
Post by אריה ענק משער האריות » Tue Aug 07, 2018 6:18 pm
Post by steve » Tue Aug 07, 2018 6:32 pm
Thanks.
Could you post some screenshots of 2.0.2 on Windows with Hebrew selected so that I can log what the differences are (I'm not on Windows and I don't have a RTL language installed).
Post by אריה ענק משער האריות » Tue Aug 07, 2018 7:30 pm
Post by steve » Wed Aug 08, 2018 11:20 am
Thanks. I've logged this on the Audacity bug tracker.
I suspect that the difference is due to the recent update from WxWidgets 3.0 to 3.1.
zohar_ml
Post by zohar_ml » Wed Aug 08, 2018 2:04 pm
Version 2.1.0 on windows also works fine.
I will stick with this until the fix will come.
Post by אריה ענק משער האריות » Wed Aug 08, 2018 2:09 pm
Is there a way around the problem?
Post by steve » Wed Aug 08, 2018 2:15 pm
Until the problem is fixed, I think the only workaround is to set Audacity to use a "Left to Right" language (such as English).
