Will not record ruler not at zero Latency issue
Permanent link to this post Posted by Jackxxx » Sun Apr 23, 2017 10:10 pm
Does anyone no how to correct this?
Please see attached image.
Latency Message
Thank you,
Reason: place image in-line
Jackxxx
Re: Will not record ruler not at zero Latency issue
Permanent link to this post Posted by steve » Mon Apr 24, 2017 7:35 am
I presume that you were trying to record something into a project that already contained one or more tracks, and when you pressed the record button, that message popped up instead of recording?
If that's the case, then most likely what happened is that the recording stalled for some reason, so a very short or zero length track was produced.
Which version of Audacity are you using?
What operating system are you using?
What were you trying to record?
Are you trying to make an overdub recording?
What settings are selected in the device toolbar?
Is "Software Playthrough" enabled in the "Transport" menu? (normally it should be off / not selected).
Return to Audiobook Production
Who is online
