Imbalance
Imbalance
Permanent link to this post Posted by SoundCard » Thu Apr 06, 2017 8:47 pm
If my waveforms aren't symmetrical, is it usually the fault of the soundcard? I can't see the mic causing that.
Is this a major problem-causing error? So far, I can't discern any audible problem. Just curious!
Win 10
Asus computer
SoundCard
Re: Imbalance
Permanent link to this post Posted by flynwill » Fri Apr 07, 2017 3:59 am
Try removing any DC offset per the instructions here: http://manual.audacityteam.org/man/dc_offset.html
We have noticed that it is not uncommon for voices to be "unbalanced" as you say, if removing DC offset doesn't make any visual difference I would say "Don't worry about it, it's Normal".
If there is a shift then it indicates a small fault in either your soundcard or your preamp (but more likely the soundcard). If the offset is small I wouldn't worry about.
Post a sample and we'll have a look.
flynwill
Operating System: GNU/Linux other
Return to Audiobook Production
Who is online
Users browsing this forum: No registered users and 3 guests
