Please evaluate this sample
Re: Please evaluate this sample
Permanent link to this post Posted by kozikowski » Thu Apr 06, 2017 1:13 am
Some of that forward honky sound could be cause by the table. Spread a heavy blanket, towel or multiple layers of cloth on the whole table under the microphone. That blue thing is a furniture moving blanket.
The book and orange bath towel are a terrific way to eliminate floor or table vibrations. You need both (it doesn't have to be Stephen King).
Re: Please evaluate this sample FILE RELINKED
Permanent link to this post Posted by Trebor » Thu Apr 06, 2017 12:33 pm
CantorHank wrote:https://www.dropbox.com/s/7lzx5uw3d8ofh6d/preface_to_the_third_edition_raw.wav?dl=0
There's constant mains-hum and and intermittent metallic ringing at ~5Khz.
Those can be removed using this set of notch filters in Audacity's nyquist prompt ...
Code: Select all
(setf *track* (notch2 *track* 59 5))
(setf *track* (notch2 *track* 119 10))
(setf *track* (notch2 *track* 4780 50))
(setf *track* (notch2 *track* 5050 50))
(highpass8 *track*  20)
what the code looks like in Audacity's nyquist prompt.png (9.18 KiB) Viewed 578 times
''By George Topas'' , Before-After Notch filters & Paul-L DeClicker on default settings.wav
notch-filters have removed mains-hum & metallic ringing @ ~5KHz
(594.63 KiB) Downloaded 31 times
[ Paul-L's DeClicker plugin for Audacity is here ... viewtopic.php?p=245549 ]
Trebor
Permanent link to this post Posted by kozikowski » Thu Apr 06, 2017 3:28 pm
So now you know what a better quality microphone in a quiet, echo-free room will do for you. Good quality voice recording is not for the easily frightened, even if you're not reading for audiobooks.
Permanent link to this post Posted by CantorHank » Thu Apr 06, 2017 8:06 pm
Koz and Trebor,
Thanks for taking the time to provide a full and comprehensive answer.
Will work on things......I now believe that it isn't the computer fan causing the hum but rather a nearby fridge motor. I will deal with that.
I will try to make some progress on 1 or 2 chapters and then submit them to Audacity to be sure I am on the right track.
Thanks again,
HT
CantorHank
Operating System: Windows 7
Previous
Return to Audiobook Production
Who is online
Users browsing this forum: No registered users and 2 guests
