Please evaluate this sample
Permanent link to this post Posted by CantorHank » Wed Apr 05, 2017 2:38 pm
Made with Audacity 2.1.3
Windows 7
Blue Snowball ICE mic
Voice Meeter interface
https://www.dropbox.com/s/jjcnou0whsyb5 ... n.wav?dl=0
I would be grateful for your critique
Thanks
HT
CantorHank
Operating System: Windows 7
Re: Please evaluate this sample
Permanent link to this post Posted by kozikowski » Wed Apr 05, 2017 3:52 pm
I'll listen when I get back home. We like it when the poster includes a goal. "I want to read for AudioBooks."
Some of the requirements shift depending on what you're doing.
Permanent link to this post Posted by Trebor » Wed Apr 05, 2017 4:26 pm
CantorHank wrote:https://www.dropbox.com/s/jjcnou0whsyb5ng/prefac_to_the_third_edition.wav?dl=0
The sibilance is excessive ...
furnaCe , topaS , prefaCe.wav
(627.79 KiB) Downloaded 23 times
There is a tool to reduce sibilance called a De-Esser .
However the sibilance on your recording is so extreme that tool isn't sufficient.
I think you'll have to change the position of the mic so it's not directly in the air-stream from your mouth.
[There's also a bit too much noise-reduction].
Trebor
Permanent link to this post Posted by steve » Wed Apr 05, 2017 7:15 pm
Is this a "straight off the mic" recording, or have you processed it? If it's been processed, please post a raw "straight off the mic" sample.
Re: Please evaluate this sample for Audio Book quality
Permanent link to this post Posted by CantorHank » Wed Apr 05, 2017 7:46 pm
Dear Trebor, Steve and Koz,
You are right: trying to create an audio book of my father's memoirs which are still selling in both hard copy and ebooks.
Thanks for the help so far. This clip is raw as per instructions. Also, tried using the mic on side rather than direct.
Windows 7
In process of downloading fish filets de-esser.
Hoping for additional comments.
Thank you
https://www.dropbox.com/home/iron%20fur ... on_raw.wav
HT
CantorHank
Permanent link to this post Posted by Trebor » Wed Apr 05, 2017 11:01 pm
CantorHank wrote:https://www.dropbox.com/home/iron%20furnace/Audio%20Edition?preview=preface_to_the_third_edition_raw.wav
I'm just getting an error message from DropBox ...
The folder ‘/iron furnace/Audio Edition’ doesn’t exist.
Trebor
Re: Please evaluate this sample FILE RELINKED
Permanent link to this post Posted by CantorHank » Wed Apr 05, 2017 11:50 pm
Trebor,
Sorry for the invconvenience.
https://www.dropbox.com/s/7lzx5uw3d8ofh ... w.wav?dl=0
HT
CantorHank
Permanent link to this post Posted by kozikowski » Thu Apr 06, 2017 12:11 am
I didn't see any excessive sibilance. I think that's just the way you sound. But I did run three different programs to get rid of all the background noise. (attached) Then I made it a little louder. See how you like it. Compare it to the one you posted on-line.
Do you have a window fan or air conditioning system? Do you have a desktop PC for recording? We could be listening to the cooling fans in the computer. MMMMMMRumbleRumbleRumble. Microphone suppliers insist that you can crank out the quality work if only you buy their microphone, but it's a little more involved than that. You do need a quiet room.
Describe the room. Are you recording in your office? I can describe how I did the noise reduction so you can do it, but it's usually best to eliminate the noise while you're recording.
The show is probably enough for home and family listening, but I don't think ACX AudioBook is going to accept it if that's the goal.
preface_to_the_third_edition_ProcessedForNoise.mp3
(207.35 KiB) Downloaded 24 times
Permanent link to this post Posted by CantorHank » Thu Apr 06, 2017 12:21 am
Thank you.
I have been using Audacity's noise reduction but the request was made for a "raw" file.
When I record, the hvac in the house is off and the mike is on a stand with a pop filter. Behind the mic is a draped blanket to dampen echo.
The PC is on the floor under the desk and I could probably add a blanket to help dampen that.
Did you by any chance add some bass to the raw file.....it does sound a heck of a lot better!
If you feel that the sibilance is not as bad as previously, then perhaps by the side speak into the mike (as I do with a headset boom mic for other activities), perhaps I can practice a bit and minimize that problem.
If I were to provide you with a 2-1/2 minute sample which I will clean up, noise reduce, de-ess, etc, would you be able to evaluate that?
HT
CantorHank
Permanent link to this post Posted by kozikowski » Thu Apr 06, 2017 1:08 am
There is a trick to throwing a blanket over your computer. DO NOT BLOCK ANY AIR HOLES OR VENTS. Since it's the air holes and vents making the noise, you can work that out. I'll watch.
It's not unusual for people to figure out a way to move the computer out of the room...or use a machine that doesn't make noise.
you be able to evaluate that...performance
Oddly no. We can certainly tell you if you meet ACX AudioBook technical standards (Volume shall be this and so, etc.) but theatrical quality is entirely between you and ACX. As in the above examples, we all heard something different. (I think an elephant is very like a snake.)
I can tell you what I did if that was helpful.
We have a custom voice filter called LF Rolloff for Speech. It reduces the bass in the presentation in a very precise way. A similar tool is common in field film shoots to get rid of natural rumble and some wind sounds.
http://www.kozco.com/tech/audacity/Docu ... ch.xml.zip
Unzip it and install it in the Audacity Equalizer.
Adding Custom Audacity Equalization Curves (LF-rolloff as an example)
-- Select something on a timeline.
-- Effect > Equalization > Save/Manage Curves > Import
-- Select LF_rolloff_for_speech.xml > OK. (it won't open a ZIP. You have to decompress it)
-- LF rolloff for speech now appears in the equalization preset curve list.
That left one of the motor hum tones which I got rid of with a custom tone remover (notch filter).
Select the whole show by clicking just above MUTE. Effect > Notch Filter.
Screen Shot 2017-04-05 at 17.58.06.png (22.53 KiB) Viewed 664 times
OK
Then simple noise reduction.
Drag-select a room-tone only portion of the show and Effect > Noise Reduction: Profile.
Effect > Noise Reduction: 9, 6, 6 > OK.
Then boost the volume a little.
Effect > Normalize...
Screen Shot 2017-04-05 at 18.00.54.png (26.4 KiB) Viewed 664 times
OK.
And you got what I got. So no, it's not simple noise reduction and most of those steps will probably vanish if you move the computer (hint hint).
Next
Return to Audiobook Production
Who is online
Users browsing this forum: No registered users and 2 guests
