Noise Floor no higher than -60db
Permanent link to this post Posted by Jackxxx » Sat Feb 25, 2017 10:12 pm
Please forgive my obvious to most question.
What would a noise floor number be that is considered higher than -60db?
My reason for asking is that when I complete a recording the noise floor is about -64db, using the ACX Check, but when my clean-up of a recorded file is complete the noise floor might be between -75db and -85db. It still passes the ACX Check, so my assumption is that -75db is quitter than -64db. Is this correct?
Thank you,
Jackxxx
Re: Noise Floor no higher than -60db
Permanent link to this post Posted by Trebor » Sat Feb 25, 2017 10:23 pm
Yes : -75db is quieter than -64db.
Confusingly a higher noise-level is a lower (negative) number.
Trebor
Return to Audiobook Production
Who is online
