applying 2 effects
applying 2 effects
Permanent link to this post Posted by newmarket2 » Tue Oct 18, 2016 3:56 pm
Can 2 effects be applied to the same track?
newmarket2
Re: applying 2 effects
Permanent link to this post Posted by Gale Andrews » Tue Oct 18, 2016 5:20 pm
newmarket2 wrote:Can 2 effects be applied to the same track?
Yes, one first, then the other.
Permanent link to this post Posted by kozikowski » Tue Oct 18, 2016 7:23 pm
Please note if you don't like the work, you have to remove the effects in the reverse order applied. There is no 1, 2, 3 and then remove 1. You have to UNDO 3, then 2, and then 1.
Return to Audiobook Production
Who is online
