Audio questions?
Audio questions?
Permanent link to this post Posted by bobpreece333 » Fri Oct 14, 2016 8:53 pm
Moderator: Moved to "Audiobook Production"
Hello!
My name is Bob.
The idea that I might be able to
Pose a question here and
Get a response from a real human -
WORKING FOR FREE -
Blows my {word rejected} mind.
So it's probably robots or something
Like the CIA
Keeping us happy
By soVling our little problems
But, that being said
I have three questions:
How do you open the RMS tester program you guys recommend? I tried audacity and it didn't work.
Recorded an audio book. All files came back too quiet. Is there anyway to change that without re-recording?
When I talk into my microphone louder, the green bars in the middle at the top go up to the numbers they talk about. Is that bar the RMS?
Honestly, thank you so much.
Whatever you are
That might answer
One
Or all of the questions
Anytime
No rush
If it is too obvious
Too dumb a question
Say nothing
And I will work harder.
That's exactly the thing the CIA wants to stop.
Love
Bob, Poet
bobpreece333
Re: Audio questions?
Permanent link to this post Posted by kozikowski » Sat Oct 15, 2016 2:41 am
Audacity is an Audio Production program that you can get for free from here:
http://www.audacityteam.org/download/windows/
... assuming you're using Windows.
You can and people do record, produce, correct, export, and submit AudioBook work with Audacity. But as you're finding, recording AudioBooks is not particularly easy. Very few people buy a Yeti microphone, announce a book and become internationally famous.
We created a tool called ACX Check which is a separate download and appears under Analyze. It measures the three things that the ACX company measures just to get your submission in the door.
http://wiki.audacityteam.org/wiki/Nyqui ... #ACX_Check
viewtopic.php?p=297423#p297423
It's good to run at least one of your chapters through that test to see what happened. It's terrifically easy to chase your tail. "I fixed the loudness, now the peaks are too high." or "I fix the peaks and the noise fails."
In the current Audacity 2.1.2, you can change the sound meters to be multi-colored. This makes it easy to see them out the corner of your eye while you're recording. Since you don't have a recording engineer (I assume), you're stuck doing that job. Voice peaks should be yellow-ish which works out to about -6dB. That's good, correct sound levels. You can worry about RMS, etc, later.
It's possible to rescue your existing work if it's not too far off. Drag-select about 10 seconds stereo or 20 seconds mono from one of your chapters. File > Export Selected as WAV (Microsoft) 16-bit and post it here. Scroll down from a forum window > Upload attachment. It's not a dreadful idea to do all your production in mono (one blue wave) and use WAV and not MP3 until you have to submit. I'm assuming ACX. They require MP3 submission. You can create serious sound damage and distortion by making an MP3 of an MP3 of an MP3.
Let's see what you have and we'll talk you through the rest of it.
Is it ACX? We know more or less what they're searching for, so we can give you a good push for submitting.
And just so I don't give you a false sense of completion, once your submission passes the ACX Robot, it still has to pass Human Quality Control. It's possible to beat your submission with a stick just so it squeaks past the ACX Robot, but sounds like a bad cellphone. This is where those submissions die.
But we have to get you past the robot first.
Describe your studio. "I have a Blue Yeti microphone on my desk..."
Permanent link to this post Posted by kozikowski » Sat Oct 15, 2016 2:43 am
Missed one. Submit a raw recording to the forum. Do Not process, filter or change it.
Return to Audiobook Production
Who is online
Users browsing this forum: No registered users and 2 guests
