Compression?
AAS
Compression?
Post by AAS » Fri Mar 13, 2015 6:07 pm
HELP! I'm doing an audiobook narration (my first). How do I initiate Compression on an audio/vocal file?
Re: Compression?
Post by kozikowski » Fri Mar 13, 2015 6:40 pm
Drag-select the portion you want to correct, or, click above the MUTE button for the whole file. Effect > Compressor. The compressor settings depend on where you start and where you want to end.
AAS
Re: Compression?
Post by AAS » Tue Mar 24, 2015 2:31 pm
Thanks! seems to work.
