Audio "booming"?
LivingInternet
Audio "booming"?
Post by LivingInternet » Sun Dec 16, 2018 5:13 pm
Hi, most comments I get on the audio for my online course are positive after applying the steps in viewtopic.php?f=64&t=102096
However, I have had a couple negative comments, including one that it was distracting because it sounds like it is "booming". I don't think my ears are sensitive enough to validate or reject this comment. So I'd appreciate any feedback on the attached excerpt.
audio-excerpt1.wav
(734.52 KiB) Downloaded 45 times
Does it sound like it "booms", or has other undesirable characteristics? If so, is there a filter I can apply to make it more pleasant?
Thanks much,
Bill
Re: Audio "booming"?
Post by steve » Sun Dec 16, 2018 5:46 pm
The frequency range 80 to 200 Hz could come down a little. https://manual.audacityteam.org/man/equalization.html
Trebor
Post by Trebor » Mon Dec 17, 2018 3:36 am
There is a some audible reverb from the room, which bassy.
So cutting the bass will reduce that "boomy" reverb ...
De-boomy equalization 'curve'.png (20.91 KiB) Viewed 803 times
De-Boomy.xml
Preset data for the above curve to be imported into Audacity's equalizer
(388 Bytes) Downloaded 40 times
Voxengo have a free real-time spectrogram plugin which works in Audacity,
where you can see the levels of each frequency, (even if you can't hear them).
Voxengo SPAN demo.gif (1.82 MiB) Viewed 796 times
LivingInternet
Post by LivingInternet » Wed Dec 19, 2018 10:26 pm
Thanks, that helps a lot. You had previously suggested adding some presence. I don't think I added enough. Would you suggest adding more, and if so how much?
Is there anything else you think it needs?
Trebor
Post by Trebor » Thu Dec 20, 2018 5:51 am
This equalization curve incorporates de-boomy, mid-boost & boost-presence ...
DB+BM+BP.XML
data for the above equalization curve
(53.4 KiB) Downloaded 42 times
Increasing presence will inevitably increase sibilance , so you may have to de-ess* afterwards.
[ * My de-ess suggestion would be one application of TB Sibalance at 100%, 00ms, -10bB ]
LivingInternet
Post by LivingInternet » Thu Dec 20, 2018 11:41 pm
Thanks much.
