Removing Part of Audio in One Track - Need Help
Audacity Podcaster Forum.
Permanent link to this post Posted by lsedaghat » Fri Sep 23, 2016 11:44 pm
Hi, I have a single audio track where people are talking, but there's also the sound of a river running in the background of their conversation while they're speaking. Is there anyway I can delete the sound of the river without cutting out the people's audio?
I recognize that the sounds overlap and it's one track, but was hoping if there were any advanced trips on how to do this. Thanks so much!
lsedaghat
Re: Removing Part of Audio in One Track - Need Help
Permanent link to this post Posted by Gale Andrews » Sat Sep 24, 2016 1:15 pm
No, you will almost certainly not completely remove the river assuming you mean this is a mono track. If you are really lucky you many find that Noise Reduction with the Noise Profile set to the river helps a little.
For more detailed analysis you could look in Spectrogram View at the frequency range of the voices. The voices may have a narrow range. You may be able to boost the amplitude of that range without making the river much louder, by using the Spectral editing tools or Equalization.
If it is a stereo track you could try Vocal Reduction and Isolation.
You may just make it worse, whatever you do.
Return to Podcasting with Audacity
Who is online
Users browsing this forum: No registered users and 3 guests
