How to remove loud sounds? Envelop? Anything else?
Audacity Podcaster Forum.
Permanent link to this post Posted by Ceodryn » Sun Aug 28, 2016 11:52 pm
Hi,
I am new to Audacity. I have recorded a roleplaying gaming podcast (omnidirectional) with the Blue Yeti microphone placed in the center of the table. Throughout the audio, I sometimes get too loud sounds, whether it be a player hitting the table, dropping a glass token, or maybe a pop sound. I understand I can use envelop to go and lower every peak, but it takes way too much time as there are many of them over 4h of podcast.
If there a function or effect that basically will lower every peak to over the 0.55 threshold of the envelop down to 0.55 or lower? Basically, is there an effect that automate envelop throughout the wave form?
Thanks in advance
Ceodryn
Re: How to remove loud sounds? Envelop? Anything else?
Permanent link to this post Posted by kozikowski » Mon Aug 29, 2016 12:14 am
That would be Effect > Limiter.
http://manual.audacityteam.org/man/limiter.html
The effect gets more vicious as you work down the option list. By the time you hit Hard Clip, the tool is brutally whacking off the tops of the blue waves.
You can get rid of table conduction noise with the Wamsutta/Doubleday trick.
Permanent link to this post Posted by kozikowski » Mon Aug 29, 2016 12:18 am
That blue thing is a furniture moving blanket. That's not a bad idea, either. That will get rid of dropping loose change on the table noises and will make the voices clearer. That last one is a little magic. The blanket keeps vocal table reflections out of the microphone.
This was a broadcast sound shoot. Ignore everything but the blanket on the table. It's folded over in this case.
Permanent link to this post Posted by Trebor » Mon Aug 29, 2016 1:10 am
Ceodryn wrote:... If there a function or effect that basically will lower every peak to over the 0.55 threshold of the envelop down to 0.55 or lower? Basically, is there an effect that automate envelop throughout the wave form?
Limiter on "Soft limit", with no "Make-up gain" ...
soft Limit , -5dB, No make-up gain.png (10.26 KiB) Viewed 1586 times
Trebor
Permanent link to this post Posted by Ceodryn » Mon Aug 29, 2016 12:52 pm
Thanks for the help! I'll add a blanket.
For the limiter, I have looked for it, and do not see it under my Effects menu (screenshot below). I am using a Mac.
Screenshot 1: https://www.dropbox.com/s/bv5shtwzsqd4879/Limiter1.png?dl=0
I however have an effect called AUPeakLimiter, but with a very different menu:
Screenshot 2: https://www.dropbox.com/s/xeo7gntzecm075e/Limiter2.png?dl=0
Is the AUPeakLimiter a newer version, and then how does it work? Or where can I find the Limiter plug-in?
Ceodryn
Permanent link to this post Posted by steve » Mon Aug 29, 2016 1:32 pm
To reduce audio above a certain threshold to less than the threshold level (more reduction than a limiter), then you can use the "Pop Mute" effect: http://wiki.audacityteam.org/wiki/Nyqui ... s#Pop_Mute
Download and installation instructions are here: http://wiki.audacityteam.org/wiki/Downl ... s#download
Permanent link to this post Posted by steve » Mon Aug 29, 2016 1:33 pm
Ceodryn wrote:Or where can I find the Limiter plug-in?
The Limiter plug-in is included in the current (2.1.2) version of Audacity. Details can be found in the manual here: http://manual.audacityteam.org/man/limiter.html
If you have an old version of Audacity, get the current version from here: http://www.audacityteam.org/download/
Permanent link to this post Posted by cyrano » Mon Aug 29, 2016 4:39 pm
Ceodryn wrote:I however have an effect called AUPeakLimiter, but with a very different menu:
AU effects are Apple Units. They come with Garageband or Logic, but can be used in other DAW's (Digital Audio Workstations) too.
Some AU's might not work with Audacity, tho. But it's easy enough to try and find out if they do.
cyrano
Permanent link to this post Posted by Ceodryn » Mon Aug 29, 2016 6:26 pm
Ok thank you for the help. I had 2.1.0 of Audacity. I just installed the latest one.
One overall question that may be dumb for expert, but the scale of the sound form goes from -1.0 to 1.0, yet all effects (like Limited) are asking me the dB threshold. How do I convert the Audacity scale on the left to dB? In practice, say I have sound extending to +1 or -1, that I want to bring back to .6, how do I know how much effect to apply? (and vice versa when I try to amplify).
Another overall question: For a gaming podcast where I recorded a group (omnidirectional), what should be the minimum editing that I conduct (That wouldn't take me more than 2h on a 4h recording, otherwise I simply have no time to do so). So far, I am doing, in the order:
- Noise reduction
- Truncate silence
- Compress dynamic 1.2.6
- Envelop to reduce peaks, but I'll now use Limter
Finally, is there a tutorial written or video on how to use Audacity for podcast editing that you would recommend for newbies?
Ceodryn
Permanent link to this post Posted by Trebor » Mon Aug 29, 2016 9:19 pm
Ceodryn wrote: How do I convert the Audacity scale on the left to dB
See the "amplitude ratio" column in the conversion-table here ... https://en.wikipedia.org/wiki/Decibel
You can convert the scale on the left to dB ...
Waveform in dB scale.png (7.95 KiB) Viewed 1568 times
Ceodryn wrote: So far, I am doing, in the order:
- Noise reduction
- Truncate silence
I'd use the limiter before the compressor. The response-time of the Limiter is much shorter than a typical compressor.
Trebor
Next
Return to Podcasting with Audacity
Who is online
