Tips to improve a VoIP call
Any tips on how I can improve my guests voice (recorded VoIP) for podcast quality?
https://drive.google.com/file/d/1uS1c0N_sxT_zwZ6HIXJdKOHNz2YnYCIh/view?usp=sharing
My guest’s audio recording on Zencastr, which records podcasts in studio-quality from your web browser (https://zencastr.com/) did not save for some reason and I was unaware until after the call had ended
(Zencastr support said: “As for the cause, this can be due to the user’s Local Browser Storage. Your guest must have enough local browser storage to properly record.”)
Zencastr sent me a backup of the guest’s audio stream from the VoIP call, saying ,
“This file is the audio that was streamed over the internet during the call so the quality is not going to be as high as a local recording”.
Prefer not to have to re-record.
Greatly welcome all tips and advice on improving the quality of this audio :smiley:
Thank you
from 25 to 29 seconds there’s no recoverable voice except the Scottish man saying “yup” at 28seconds.
Hi Trebor,
Ah, sorry this is just a very short clip of my guest speaking and responding to me, not the full audio (I have not shared my voice/track here) to give an example of the sound quality.
The ‘yup’ is just a response to me talking.
I am looking for advice on how I can improve the quality of the sound.
Thankfully, my guest has a good strong voice and so I am hoping I can get away with adding some effects to just make the quality sound a little better :slight_smile:
Thank you
#1: Compression, to make volume louder & more uniform …
#2: De-essing , (particularly as compression will have made sibilance louder)
#3: Limiter (without make-up gain) to ensure 1dB headroom.
Thanks so much - this is awesome :smiley:
i have posted on the original de-esser post also, but please could you tell me when installing the nyquist plug-in, should I ‘allow’ or ‘disallow’ overwriting?
Should leave it on the default of ‘disallow’, unless you want to permanently replace a plug-in with the same name, see … Nyquist Plugin Installer - Audacity Manual
Desibilator is essentially Paul-L’s De-Esser, but Desibilator won’t replace it as they have different names …
okay great, thank you!
