My mic moved mid podcast - fix available?
Audacity Podcaster Forum.
benspod
Operating System: macOS 10.15 Catalina
Post by benspod » Wed Dec 30, 2020 10:24 pm
Hey forum members!
I recorded a podcast interview and midway through the interview I only just remembered to clip on my mic so there is a noticeable difference halfway through - I have no idea if I can make the first half sound the same as the last half?
I looked at spectrum analysis to try somehow apply one to the other, and some effects that I had no idea what all the options meant.
Has anyone managed to process a section to make it sound similar before?
Thanks!
BEN
far away spectrum.txt
(5.94 KiB) Downloaded 17 times
near mic audio.wav
(1.25 MiB) Downloaded 19 times
near mic spectrum.txt
(5.93 KiB) Downloaded 16 times
far away audio.wav
(1.66 MiB) Downloaded 19 times
Trebor
Re: My mic moved mid podcast - fix available?
Post by Trebor » Thu Dec 31, 2020 1:21 am
In a word: No.
It's possible to make the "far" spectrum match the "near" spectrum ...
near-far with matching EQ.flac
(589.73 KiB) Downloaded 21 times
But they are still clearly different because they have different amounts of reverberation.
( There are de-reverb plugin$, but they are no use with strong reverberation, which is the case here )
Post by kozikowski » Thu Dec 31, 2020 2:38 am
How? We're always on the lookout for home techniques to record remote interviews. Most don't work.
Now you know why producers wear headphones and listen to the show while it's being recorded.
benspod
Post by benspod » Thu Dec 31, 2020 10:17 am
In a word: No.
Thanks for the attempt and advice Trebor! I had a hunch it may not be recoverable :roll:
benspod
Post by benspod » Thu Dec 31, 2020 10:21 am
Yes I'm a home podcaster with StreamYard and Descript - so don't employ a producer unfortunately.
But most podcasters I speak with are working remotely due to the pandemic and still putting out their shows, I need to ask them their secret sauce !
Post by steve » Thu Dec 31, 2020 11:09 am
Most podcasters are in the same situation.
Being the producer + sound engineer + voice talent, all at the same time, is difficult, but not impossible. It can also be personally rewarding when everything goes to plan and you get a good podcast - you can say with pride: "I did that" :)
A large part of the "special sauce" is "attention to detail".
One "trick" passed onto me by an old friend, was to always sit in the same chair at the same table, with the legs positioned on electrical tape "X"s stuck on the floor. On the table he had a piece of wooden dowel, cut to the optimal length for distance between his mic and his mouth. When beginning a recording, he would sit on the chair, check that the chair legs were on the "X"s, then position the mic using the wooden dowel to measure the distance, set the recording levels, and then start.
I think that many podcasters develop their own little rituals for setting up.
