help fixing this audio quality
Audacity Podcaster Forum.
Interforo
Re: help fixing this audio quality
Post by Interforo » Sat Dec 12, 2020 4:02 pm
I can't find the 2 plugins separate to download
I have installed and re-installed Audacity 2.4.2 run the Nyquist installed but yet I can't see the 2 plugins under Effect :(
Trebor
Post by Trebor » Sat Dec 12, 2020 5:06 pm
I can't find the 2 plugins separate to download ...
LevelSpeech2.ny
(2.55 KiB) Downloaded 39 times
desibilator.ny
(56.03 KiB) Downloaded 46 times
If you can't get the Nyquist installer to work, just put copies of the two ".ny" files attached (above)
into this (hidden) Windows folder, (the Audacity plug-ins folder) ...
Code: Select all
C:\Users\<YourUserName>\AppData\Roaming\audacity\Plug-Ins
Then they will appear in the plug-in manager, (you may have to restart Audacity).
Then enable them in the plug-in manager, then they will be available in the effects menu ...
Interforo
Post by Interforo » Sat Dec 12, 2020 5:17 pm
thank you for your patience and kindness I was able to apply the effects now!
Would you recommend any other?
The volume maybe a bit high still?
How about the NORMALIZE effect?
Trebor
Post by Trebor » Sat Dec 12, 2020 6:13 pm
RMS normalize, (yet another plugin :roll:), as a final step before you upload the podcast.
-18dB RMS is a typical value for speech,
but the platform you're uploading to may have their own standards for RMS loudness.
e.g. apple podcasts -15dB to -17db, others say -19dB.
RMS normalize to -18dB.gif (123.15 KiB) Viewed 549 times
