help fixing this audio quality
Audacity Podcaster Forum.
Interforo
Post by Interforo » Fri Dec 11, 2020 4:24 pm
Hi,
I have recorded a call with 3 people for my podcast.
Here is an extract. Can someone recommend what to do on audacity in order to improve the quality of the audio?
Note that this is the file as I get it after the recording, no edits have been made yet.
Open to your recommendations
Thanks
File with a sample:
https://we.tl/t-gMR7qIlxcB
Re: help fixing this audio quality
Post by kozikowski » Fri Dec 11, 2020 4:59 pm
Screen Shot 2020-12-11 at 8.57.49 AM.png (56.4 KiB) Viewed 734 times
Maybe post somewhere we don't have to agree to anything.
Interforo
Post by Interforo » Fri Dec 11, 2020 5:09 pm
Trebor
Post by Trebor » Fri Dec 11, 2020 5:14 pm
I have recorded a call with 3 people for my podcast. Here is an extract.
LevelSpeech2.ny plugin on default settings,
then desibilator.ny plugin with threshold at -10dB, (was -20dB), all other settings default.
excerpt, before-after.flac
"after" maybe needs more de-essing ?
(1.34 MiB) Downloaded 31 times
Interforo
Post by Interforo » Fri Dec 11, 2020 6:06 pm
Thank you!
Do I have to download The 2 plugins you mentioned?
Trebor
Post by Trebor » Fri Dec 11, 2020 11:03 pm
... Do I have to download The 2 plugins you mentioned?
Yes. They are specifically for Audacity & are called NYquist plugins.
In the latest version of Audacity there is a feature to install them ...
https ://manual.audacityteam.org/man/nyquist_plug_in_installer.html
After installation you still have to enable them in the plug-in manager before they appear in the effects menu.
https ://manual.audacityteam.org/man/manage_effects_generators_and_analyzers.html
Interforo
Post by Interforo » Fri Dec 11, 2020 11:33 pm
I have enabled the nyquist but dont see it under effect
Anyway what to do with the effect?
Can’t see the other you mentioned
Trebor
Post by Trebor » Sat Dec 12, 2020 12:46 am
I have enabled the nyquist but dont see it under effect ...
You have to click on the "OK" button below the "Enable" button in the plugin-manager to make changes persist ...
When enabled those Nyquist plugins then should appear in the (alphabetical) effect menu as "Desibilator" & "Level Speech 2".
"Level Speech 2" makes all the people sound equally loud.
"Desibilator" reduces sibilance which can become excessive after applying "Level Speech 2".
Interforo
Post by Interforo » Sat Dec 12, 2020 1:10 am
Look, plugin installed
But unfortunately the 2 effects are not in the list
Trebor
Post by Trebor » Sat Dec 12, 2020 1:15 am
Plugin manager should look like this ...
If the Nyquist installer has not worked, you can put copies of "LevelSpeech2.ny" & "Desibilator.ny" into this hidden folder ...
Code: Select all
C:\Users\<YourUserName>\AppData\Roaming\audacity\Plug-Ins
Then enable them in the plug-in manager.
