connecting jingle palette to audacity
Audacity Podcaster Forum.
Garygatehouse
Post by Garygatehouse » Tue Mar 10, 2020 4:21 am
windows 10-I do a podcast (recorded) using Audacity on my HP desk top. I want to connect JINGLE PALETTE TO AUDACITY and use Jingle while I am doing (recording) my show. Is there anyway I can do that??
Gary :D
Trebor
Re: connecting jingle palette to audacity
Post by Trebor » Tue Mar 10, 2020 6:33 am
Garygatehouse
Post by Garygatehouse » Fri Mar 05, 2021 4:10 am
seems virtual cable does not work would a mixer work
Post by steve » Fri Mar 05, 2021 9:36 am
would a mixer work
If you use a separate computer to run Jingle Palette, then it would be easy to get that working with a mixer.
Just plug your mic and the Jingle computer into the mixer as inputs, then output from the mixer into your recording computer.
It "may" also be possible with a single computer and a mixer, but configuring the signal paths would be much more tricky.
