Need help with something regarding an MP3
This may seem strange to almost everyone that's even looked at this thread. But anyhow, I'm just wondering, is there a way to replicate the sound in this MP3 file that occurs at the 50 to 57 second point without copying the actual portion mentioned? I'm looking for a way to do it using the pitch or speed adjustment functions. But any method at all is fine with me, except trying to rerecord the original which is something I've been trying to do for over a year.
I'm not offended by anyone cracking up laughing just reading this question. But anyhow. It's a recording of a bus, albeit with a bit of distortion in the file. The bit mentioned is where it gets up to 60kph, and I'd like to know if this input can be modified to portray a file of it sitting at this speed for longer. I don't want to kill my ears by listening to it in Audacity at high volume repetitively try to figure out what to do.
http://download1593.mediafire.com/zub3b ... AudFor.mp3
Thanks in advance.
Thanks in advance.
Re: Need help with something regarding an MP3
This is the section from 50s + 01527 samples to 52s + 05697 samples. I've reduced some of the crackles using the "Repair" effect (http://manual.audacityteam.org/man/repair.html)
Loop it as many times as you like by using the "Repeat" effect (http://manual.audacityteam.org/man/repeat.html)
Thanks for the response. But what I actually want to try and do is adjust the input in the section portion of the file (about the 2:10 to 2:45 mark) to where it sounds like the bit at 0:50 to 0:57. Is this possible with Audacity?
If I understand your question correctly, then you could use a "Time Track" like this:MT3269 wrote:Thanks for the response. But what I actually want to try and do is adjust the input in the section portion of the file (about the 2:10 to 2:45 mark) to where it sounds like the bit at 0:50 to 0:57. Is this possible with Audacity?
See: http://manual.audacityteam.org/man/time_tracks.html
I'm not sure how that feature works. Thanks for pointing it out anyhow though.
The file I initially linked to includes 55kph running. However, I need to be able to modify it using whatever function is available to depict the solid 60kph running in the attached file at approximately the 3:15-3:30 mark.
http://download1195.mediafire.com/avfgc ... 282%29.mp3
Also, I have attached another file that shows what I was recording, when actually wanting to get the revs mentioned. Is it possible to modify this one at all? What I'm after is trying to recreate those revs by modifying input at lower speeds so that this can be exported into a full length file of about 6 minutes in length.
http://download1585.mediafire.com/wtcd9 ... 282%29.mp3
Alternatively, are there any other free programs like Audacity that might be able to do this?
If I mess around too much with the Audacity functions, it could be very hard on my ears, so I need to know what to do in advance, rather than just experimenting, and subsequently getting angry with myself. And yes, I do this in spare time. It's not a job lol.
Thanks again.
Thanks again.
Anyone have any further suggestions for this? I still haven't figured out the magic trick, assuming there is one, and it doesn't seem like it's possible now to recapture the original.
I still haven't figured out a way to modify the audio to something that is similar to portion I mentioned, but nonetheless, is there a way to get rid of this annoying background noise in this file? I unwittingly used incorrect settings, when it turned out that I didn't need any AGC (Automatic Gain Control) functions at all for this. The only one I use is Limit2, on the odd occasion
http://download1346.mediafire.com/ye7c0 ... cnoise.mp3
I have tried noise reduction, and it hasn't worked.
The annoying [bubbly] background-noise is compression-artifacts : they are caused by using a low bit-rate , (nothing to do with AGC).MT3269 wrote:... is there a way to get rid of this annoying background noise in this file?
A free plugin called DtBlkFx can be used to reduce the bubbly compression artifacts somewhat ...
