Edit
IMO de-ess the vocal a bit more.
( de-essing can only really be done on the vocal track in isolation not when it is in the final mix)
Thank you for the tip
OneAndOnlyALG:
Thank you for the tip, any feedback on this one? http://youtu.be/p9t-X78qcHg
IMO needs more dynamic range compression , in addition to de-essing …
Better results will be achieved if the de-essing and compression are be applied to the vocal track only ,
not to the final mix as I have done here.
I think You should add more power on kicks and snares:) generally it’s not bad but not in my taste
