VST Effect
For Teachers and Educators.
Using Audacity in the Classroom.
mayue
VST Effect
Post by mayue » Fri May 22, 2015 7:52 am
At the page of Real-time preview:
"Enable: This checkbox contains a checkmark by default Enable, which enables the effect.
Remove the checkmark Enable to disable the effect (also known as bypassing the effect). Disabling makes the audio play as if the effect was closed and the effect's controls will no longer change the audio. Disabling and enabling is a convenient way to compare the "dry" (non-affected) sound with the "wet" (affected) sound while it plays in real time."
What is the "effect"? :idea: :idea:
Reason: remove color tags for readability
Contact:
Re: VST Effect
Post by steve » Fri May 22, 2015 8:03 am
mayue wrote:What is the "effect"?
It's the VST effect.
