Select multiple snippets
Hello everyone!
How to select several different snippets and in different places in Audacity?
Thank you very much friends!
I have the same question, how to select several different snippets? Thanks.
It depends on what you want to do with the snippets.
If you want to Export them, then you can use “Export Multiple”. See: https://manual.audacityteam.org/man/export_multiple.html
If you want to Cut, Delete, Split Delete, Split, Join, Copy, or Silence, see: https://manual.audacityteam.org/man/edit_menu_labeled_audio.html
For most other tasks you will probably need to do one snippet at a time.
