These MP4 files play fine in VLC media player but I was hoping I could convert them to MP3 files on my computer. When I import them to Audacity the playback is totally garbled or partially garbled. Also if I delete the garbed part in a partially garbled file then some or all of what was not garbled becomes garbled. As if it takes Audacity a while to figure out the format and get the playback correct??? I am using Linux Mint cinnamon & Audacity 3.0.3-alpha-20210727
BTW I have used Audacity for years it is an awesome product thank you so very much for this excellent tool!
Thank you so very much for the advice. I used the audacity link to down load the lasted version 3.1.2 and it solved the problem. I usually just let the software manager download the new versions and I have heard they are conservative (lag) on the versions they recommend downloading.
