How do I change the tracks of place ie, for example: change a track that is in first to the second track or vice versa?
Thank you very much!
The downward arrow in the upper right-hand corner of the Track Control Panel will expose a menu allowing you to move a track up or down. See: Audio Track Dropdown Menu
Jeez Jademan, sorry I didn’t think it was that easy, I didn’t notice the dropdown menu with this tool.
Thank you friend!
Yes, you might think there would be a way to just grab the track and move it up or down…
There is - and has been for a very long time.
You just click in the Track Control Panel "white space) holding the mouse button down and drag the track up or down.
Peter/
