Audacity on chromebooks
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Permanent link to this post Posted by wesmo » Tue Dec 13, 2016 1:28 am
Hi,
Is there any possibility of porting audacity to a chrome app for use in chromebooks in education?
From a development perspective, what would be required to get audacity running on a chromebook?
wesmo
Re: Audacity on chromebooks
Permanent link to this post Posted by steve » Tue Dec 13, 2016 9:17 am
wesmo wrote:From a development perspective, what would be required to get audacity running on a chromebook?
It would require WxWidgets to be ported to Chrome OS.
It would also require all other libraries reuired by Audacity are either ported to Chrome OS, or Chrome OS compatible alternatives found.
Even then, Audacity will be severely limited on Chromebooks because Audacity works with high quality uncompressed audio data that requires a lot of space, but Chromebooks typically only have a few tens of GB of "disk" space (because Chromebooks are primarily designed for cloud based applications).
Audacity is not suitable for cloud based operation because of the very large amount of audio data that needs to be moved around in real-time.
See also this FAQ: http://manual.audacityteam.org/man/faq_ ... tml#chrome
wesmo wrote:Is there any possibility of porting audacity to a chrome app for use in chromebooks in education?
Probably not, but there are alternatives.
Return to Feature Request Archive
Who is online
