Amplification in the last release of Audacity
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Permanent link to this post Posted by GMA » Sun Nov 06, 2016 7:45 pm
Hello everyone :)
I a have a little feedback about Audacity 2.1.0
The amplification option, don't include 'remember action", like the previous version of Audacity, which mean, when I use Amplification for many time, in the previous release, there is a check box on this windows, about that, when you check it, you will get a amplification with a specific valude in db
is there a possibility to add this option to Amplification windows, in the last version ?
GMA
Operating System: Windows 7
Re: Amplification in the last release of Audacity
Permanent link to this post Posted by kozikowski » Sun Nov 06, 2016 10:38 pm
You can get a fuzzy cousin to what you want with Effect > Normalize (attached).
That one is goal oriented. "Always put the sound peaks at -3.5dB." and the setting is sticky.
You can't define the gain it uses, though.
Screen Shot 2016-11-06 at 14.34.38.png (26.58 KiB) Viewed 765 times
Permanent link to this post Posted by kozikowski » Sun Nov 06, 2016 10:45 pm
I think you can get what you want with Effect > Equalization. Create an "equalizing curve" which is a straight line just above zero. It's rough to see, but there is a green straight line 6dB above 0dB in the picture. You may have to zoom your browser a little to see it.
That effect will add 6dB of volume to whatever you apply it to. The effect is sticky time after time and you can save it as a customized "curve" for use later.
Screen Shot 2016-11-06 at 14.41.51.png (70.49 KiB) Viewed 764 times
Permanent link to this post Posted by Gale Andrews » Mon Nov 07, 2016 3:37 pm
The current Audacity release is 2.1.2 http://www.audacityteam.org/download/windows/. Always obtain Audacity there. Audacity supplied by us has never had a "remember this value" box in Amplify, but I moved this topic to Adding Features so your vote can be counted.
You can always use Effect > Repeat Last Effect or CTRL + R to repeat the same amplification level that was last used by Amplify, if Amplify was the last effect that you used.
Permanent link to this post Posted by steve » Mon Nov 07, 2016 6:35 pm
Here's an "Amplify" plug-in effect that remembers its last used setting:
amplify.ny
Nyquist plug-in
(416 Bytes) Downloaded 29 times
It's a "Nyquist" plug-in, and to avoid confusion with the standard "Amplify" effect, this one is called "Amplify (Nyquist)..."
Instructions for installing: http://wiki.audacityteam.org/wiki/Downl ... ns#install
Permanent link to this post Posted by 123har456 » Wed Nov 16, 2016 3:14 pm
kozikowski - thankyou for the info it was News to me.
I attempted a reply with a more detailed suggestion to save time ( Esp on long recordings I make), but the Audacity Forum as erased it . . . demanding I login again . . . . yet it doesn't suggest Saving when this is about to happen.... so I'm really annoyed this thoughtful work is lost . . . never to be repeated.
It contained suggestions for Gain and Tone ( separate fly-out windows I guess, but which could be Conjoined as many corrections for Gain would also benefit from Tone change too.
123H
123har456
Permanent link to this post Posted by Gale Andrews » Thu Nov 17, 2016 4:15 pm
123har456 wrote:I attempted a reply with a more detailed suggestion to save time ( Esp on long recordings I make), but the Audacity Forum as erased it . . . demanding I login again . . . . yet it doesn't suggest Saving when this is about to happen.... so I'm really annoyed this thoughtful work is lost . . . never to be repeated.
Sometimes, using the browser's Back button can save a situation like that.
123har456 wrote:It contained suggestions for Gain and Tone ( separate fly-out windows I guess, but which could be Conjoined as many corrections for Gain would also benefit from Tone change too.
That sounds different to what you asked for in this topic, but you could start a new topic and describe it briefly.
Are you sure Chains wouldn't help?
Permanent link to this post Posted by waxcylinder » Wed Jan 25, 2017 11:48 am
And answer came there none ... :roll:
waxcylinder
Permanent link to this post Posted by Gale Andrews » Wed Jan 25, 2017 12:29 pm
I made a note of the request for Amplify to store the last used value, so I am archiving this.
Return to Feature Request Archive
Who is online
