Play, from paused, jumps to the start for no reason
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Re: Play, from paused, jumps to the start for no reason
Post by Gale Andrews » Thu Jun 16, 2016 4:36 pm
I moved the topic to "Adding Features" so we can count AndyCivil's vote (and anyone else's vote which has not already been counted) .
Edgar
Forum Crew
Post by Edgar » Thu Jun 16, 2016 4:49 pm
AndyCivil wrote:my vote would be for the following:
  • 1. Don't actually change the functionality at all, but make the buttons carry the correct icon.
  • 2. The "play from start" button should have a "play from start" icon on it.
  • 3. The "pause" button should switch to a "play" icon while in the paused state.
(Note that you wouldn't see two 'play' icons, because one is a 'play' icon and the other is a 'play from start' icon.)
+1
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
Edgar
Forum Crew
Post by Edgar » Thu Jun 16, 2016 4:52 pm
Gale Andrews wrote:I think there should be an option that actually shows a Stop and Set Cursor button.
+1
-Edgar
Post by Gale Andrews » Thu Jun 16, 2016 5:26 pm
ooh yes please +1
Or make the Stop button behavior switchable between current behavior and "Stop and Set Cursor" - controlled by a Preferences setting - default, of course, to be current behavior.
Peter already voted for a Stop and Set Cursor button, but not until now for the alternative of a Preference.
Ed has not voted before.
waxcylinder
Post by waxcylinder » Fri Jun 17, 2016 9:06 am
AndyCivil wrote: Do you know how long it takes, to scan half an hour using a scan button, just to find where you were again?
Andy, have you tried zooming to fit the entire half hour project in the Audacity Window (there is a Zoom to fit button in the Edit Toolbar). Then try using Timeline Quick-Play by clicking at various points in the timeline. I do this with one and two hour DJ Music shows and use this technique to lacate where the ads are so that I can remove them.
Seee Timeline Quick-Play in the Manual: http://manual.audacityteam.org/man/timeline.html#tqp
AndyCivil wrote: I wish desingers would regard 'current position' as having the importance that it does, and not allow users to delete/lose that important information by a fumble, without an "are you sure" confirmation!
Have you thought of dropping a temporary label to mark any such point or region of interest so that you can easily go back to it.
That's what I do with the use case above. I find the start of the ads and mark that as "ads" then find the end, mark that as "ads end" or just "end". Then I can zoom out alittle and easily select between the two temporary labels and delet the unwanted ads.
Peter
Post by Gale Andrews » Fri Jun 17, 2016 12:51 pm
waxcylinder wrote:have you tried zooming to fit the entire half hour project in the Audacity Window (there is a Zoom to fit button in the Edit Toolbar).
If it's a file like AndyCivil seems to be saying, it should be fitted when imported.
