Disable Gain and Pan sliders
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
re: Disable Gain and Pan sliders
Permanent link to this post Posted by Gale Andrews » Fri Apr 08, 2016 12:09 pm
Presumably if the disable option was in the Tracks Menu, it would apply to selected tracks? That would be more flexible than using the Track Dropdown Menu if you had many tracks.
I am not sure if customisations are needed to the Track Control Panel other than toggling Gain and Pan. If the Mute/Solo buttons were moved above the Track Info, so they were the last control to disappear when making the track less tall, would many people want to change that?
Re: Disable Gain and Pan sliders
Permanent link to this post Posted by steve » Fri Apr 08, 2016 12:46 pm
Gale Andrews wrote:Presumably if the disable option was in the Tracks Menu, it would apply to selected tracks?
I was thinking of it applying to all tracks in the current project.
If we want "per track" options, then they would go in the Track dropdown menu.
Permanent link to this post Posted by steve » Fri Apr 08, 2016 12:49 pm
Gale Andrews wrote:If the Mute/Solo buttons were moved above the Track Info, so they were the last control to disappear when making the track less tall, would many people want to change that?
I guess that someone somewhere has a workflow that requires being able to see the Track Info even when tracks are smaller than standard, so it would be a regression for them.
Re: re: Disable Gain and Pan sliders
Permanent link to this post Posted by waxcylinder » Fri Apr 08, 2016 1:55 pm
Gale Andrews wrote:I am not sure if customisations are needed to the Track Control Panel other than toggling Gain and Pan.
I'm not sure that is James' view - I seem to recall that he has plans for a major overhaul of the Track Control Panel. #
We saw an early draft at AU14 - but after that nothing has yet seen the light of day.
Peter.
waxcylinder
Permanent link to this post Posted by Gale Andrews » Sat Apr 09, 2016 12:30 pm
As long as you say "All Gain and Pan sliders" in Tracks menu, OK.
The Track Dropdown Menu is very full, so I don't think it will take more than extra Toggle Gain and Toggle Pan items. If we want a Track Control Panel customiser, perhaps it might be able to show/hide dropdown menu items.
steve wrote:I guess that someone somewhere has a workflow that requires being able to see the Track Info even when tracks are smaller than standard, so it would be a regression for them.
Perhaps we could have hover text to still show the track info, even when the track is fully collapsed?
Permanent link to this post Posted by steve » Sat Apr 09, 2016 1:57 pm
Gale Andrews wrote:The Track Dropdown Menu is very full
Yes it is, so I was thinking of adding just one new menu item called something like "Track Options..." or "Track Options >"
Permanent link to this post Posted by Edgar » Sat Apr 09, 2016 2:05 pm
If we wish to discuss changing this menu we should split this topic…
-Edgar
compiling Audacity daily
64-bit Windows 7
Edgar
Forum Crew
Operating System: Windows 7
Permanent link to this post Posted by waxcylinder » Mon Feb 13, 2017 4:18 pm
See this Proposal that I wrote today: http://wiki.audacityteam.org/wiki/Propo ... in_sliders
and also see its associated Talk page
Peter
waxcylinder
Previous
Return to Feature Request Archive
Who is online
