By the way I would sometimes find a what U hear Mix useful - the point is to not throw out the behaviour we have now.
Like Peter I prefer not to have a Preference, for ease of change on the fly. If there were only two options, I suggested an on/off control so we don't have a cascading menu. The shortcuts for mixing to an existing or new track behave as per the on/off control's settings.
I am not sure we need mix options for "ignore every control we can think of", but I don't object if some actual case is made for them and they are easily accessed. Is there some case?
Instead of telling the user to go and change the preferences, and not show them what the preference is now, we could have an arrangement like the warning for uncompressed audio files.
steve wrote:In the Tracks menu we have a sub-menu called "Mixing / Rendering"
This sub menu has 4 menu items:
Mixdown Tracks
Mixdown to New Track
Custom Mix / Render
Custom Mix / Render with Options...
"Mixdown Tracks" acts like the current "Mix and Render" except that Mute and Solo buttons are respected.
"Mixdown to New Track" acts like the current "Mix and Render to New Track" except that Mute and Solo buttons are respected.
I am still -1 to "Mixdown" as a name that means something different to "Mixing down" in Warnings Preferences. Please use a label that tells the user what will happen, or change the wording in Warnings Preferences.
It seems a confusing label to me to have "Custom Mix / Render Options" where Custom Mix / Render defaults to the current Audacity behaviour but has options for doing what you call Mixdown. Perhaps we should just drop the "Render" and call it a Custom Mix.
How do you do a "Custom mix" to a new track, notably current Audacity mix ignoring Mute / Solo to a new track? We must still be able to do that.
What is the point of Mix tracks: None?
In view of the drastic change proposed to default mix behaviour I suggest we vote on the default. I am +1 on current mix behaviour being default, assuming export mix does not change.
