If I am understanding that correctly, it would not seem to help the case I have where I want to crossfade the entire standalone clip and the end of the selection is the end of the track (and the project). Do you mean the standalone clip would have to be centered with respect to the other track?steve wrote:Are you requesting an option:Gale Andrews wrote:or rather than making that an option?
"If start of selection is equal distance from the start of the track as the end of the selection from the end of the track, then: Fade-In / Fade-out"
Of course if I had the standalone clip at the start of project, I would not have seen this "problem" if the standalone clip was fully selected. The problem would occur with the standalone at the start of the project if the selection in the standalone was not "mainly" to right of centre. It would occur in the setup in my image whenever the selection is not "mainly" to left of centre.
Yes if you zoom in that far. If you don't zoom in, and so extend the selection a long way, the fade is affected.steve wrote:Scrap that - it's been a long day.steve wrote:you could simply drag the second track above the first track
You could extend the selection just a tiny bit to the right (as little as one sample distance is enough)
It would be nice if a behaviour rule could be devised to avoid adding an option, but do you see a rule that would cover the cases described here?steve wrote:The reason that I want the fade direction to be automatic is because if you have a lot of crossfades to perform, then you can simply repeat the effect, which is extremely efficient and convenient.
Should there be a "Fade Direction" option such as
* Based on selection position (default)
* First track fades in, next fades out
I assume the non-default option would have to be that and not e.g. "Always crossfade adjacent tracks".
