That would sound logical, and would imply that if you want to record only input (channel) 2 of four, you set Audacity to record 2 channels and not 4 channels. But I've been told even under ASIO that doesn't usually work.steve wrote:I was under the impression that to use, for example, input 3 of the sound card required recording channels 1, 2 and 3, where "3" is the channel connected to input 3. That would be consistent with how ASIO works.Gale Andrews wrote:On both Windows and Mac I've been told that if you don't connect all the channels you still have to set Audacity to record the maximum number of channels so it can find the ones you want.
And if for any reason Audacity thinks inputs 3 and 4 are channels 1 and 2, it would not work for that reason.
This is from a number of users who made detailed comments when requesting improved multi-channel recording features. But obviously I have no personal experience.
