I don't know about Cyrano bit I'm certainly suggesting that - not far fetched at allsteve wrote:So you are suggesting that the linear track view is directly responsible for people recording so loud that their recording is clipped? That's a bit far fetched isn't it?cyrano wrote:It's in the numbers, Steve. WC acknowledged that when he wrote that most YT video's about Audacity distorted.
I came to Audacity from the world of cassette decks and on my Nak BX-2 with TDK-SA tapes that it was set for I knew I could successfully push the meters to near the extreme and the tape would "soak it up" (I have a fair grasp of the physics involved).
So when I started out I worked with Audacity with it's default settings (including waveform view) I thought the same applied and I pushed the levels to the max in the waveform (I had a poor grasp of DSP)- and remember the meters were a bit inadequate - that's why I worked on and helped lobby through the proposal that ended up giving us the lovely new meters with the much more useful and usable green-yellow-red colorization.
To the end of trying to help users avoid oversaturating their signal when in default waveform view I still have an outstanding proposal on the Wiki
http://wiki.audacityteam.org/wiki/Propo ... rm_display
This was originally a subtopic in the proposal for the new meters but I dug it out from there to stand alone once we had the new meters - there does seem to be some limited support for this proposal from Gale and James.
If this proposal was implemented than we might not need to consider Cyrano's point 2 in the original post of this thread, to make Waveform (dB) the default view.
I have a sneaking suspicion that changing the default view to dB might unsettle a lot of our users.
