This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the
Technical support is available via the
Help forum.
- Quality Assurance
Post
by Gale Andrews » Tue Jul 21, 2015 2:59 pm
whbjr wrote:I agree that "Normalize" does not need decimal-place accuracy in dB settings. Anyone needing that sort of accuracy should be using a different effect.
The whole point is that you *cannot* use Amplify to bring multiple tracks to the same level, unless you are going to process the tracks one at a time.
I agree that if Normalize has two decimal places of accuracy you could argue that the Normalize control in Bass and Treble should do too. I've no problem with doing that if both effects have one trailing zero.
mickthefish
- Operating System: Windows XP
Post
by mickthefish » Thu Jul 23, 2015 10:26 am
i use the NORMALISE effect quite a lot,but i never mess with the tracks seperatley as this is how they were mastered originally....mickthefish
юра00
Post
by юра00 » Mon Jul 27, 2015 9:39 am
It seems, 2 signs after decimal comma are available (2.1.2 alpha 27.07), my great thanks!
mickthefish
Post
by mickthefish » Wed Aug 12, 2015 9:33 am
when using Amplify it pays to check through your file to make sure there are no large spikes,as you will be denied a setting if there out of the spectograph window.i always use the click function first,but some need removing manually.--mickthefish.
waxcylinder
Post
by waxcylinder » Tue Aug 18, 2015 9:56 am
mickthefish wrote:i use the NORMALISE effect quite a lot,but i never mess with the tracks seperatley as this is how they were mastered originally....mickthefish
Tht depends on your equipment providing the input signal to Audacity (record deck/tape deck/FM tuner etc plus amps and cables) delivering a balanced stereo pair. In particular poor alignment of a record deck head-shell or a poorly aligned tape head can deliver unbalanced signals.
Having said that I never messed with the two stereo channels separately when I was transferring my tapes and LPs - but then I did have the tape deck professionally serviced and I took great care in setting up the record deck/cat/arm/cart
waxcylinder
Post
by waxcylinder » Tue Aug 18, 2015 9:59 am
On the topic of accuracy levels/nos. of significant figures - I don't think we have resolved this issue.
I just looked at Amplify and its "accuracy" levels just look daft to me (2.1.2 r13dbaf1 17-aug-15) - move the slider and I see 4 digits after the decimal point !
Peter
- Site Admin
Post
by steve » Tue Aug 18, 2015 10:23 am
waxcylinder wrote:On the topic of accuracy levels/nos. of significant figures - I don't think we have resolved this issue.
I just looked at Amplify and its "accuracy" levels just look daft to me (2.1.1 r13dbaf1 17-aug-15) - move the slider and I see 4 digits after the decimal point !
The issue here affects all effects and is to do with how we validate user input.
I think that this specific feature request has been dealt with in the best way we can for now, so this FR can be archived.
The broader issue of how we validate and display numerical input is something that we might like to address on the QA list, though I doubt that any developer will have time to tackle the issue until after Audacity 2.1.2 is released.
