Zoom view snap-back feature.
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
MichloIW
Post by MichloIW » Wed Jul 15, 2015 1:18 am
Greetings,
I did look over the (rather large) list of pending requests and did not see this but I apologise if it IS a duplicate.
Something I would find extremely useful for speeding up the editing process (and thus, hopefully others would) is the ability to snap back to the view setting we had after we "fit selection" or "fit project" or even, if possible, before we start zooming in.
I'm sure we all have to do this to find the extraneous noises and flaws we wish to eliminate and so I find myself zooming in and out a great deal. :)
Thank you in advance for your consideration.
Cheers.
Reason: modified title slightly to indicate nature of the request
cyrano
Re: Zoom view snap-back feature.
Post by cyrano » Wed Jul 15, 2015 10:08 am
I'll second this. It's the relatively small things that can make your workflow fly...
Post by Gale Andrews » Fri Jul 17, 2015 4:01 pm
How exactly do you want to implement it?
Years ago there was a "zoom toggle" button with a double magnifying glass that switched between the last two used levels of zoom.
Or zoom level and view position could be added to Region Save/Restore. This seems closest to your suggestion if it captured the previous zoom level and view position automatically.
cyrano
Post by cyrano » Fri Jul 17, 2015 9:17 pm
Simply having a sensible default and going back to the same default when you "unzoom" (Zoom normal) would be a good start.
When you open or import an audio file, I suppose zoom is calculated on a basis of length of the audio wave form?
I can't grok the system as it is now. Seems like a sort of "undo zoom" in stead of "go back to default".
Maybe have a default zoom level setting in preferences?
And it ties to other sensible defaults, like having "waveform db" default and not the very misleading "waveform". The current default is misleading, because a very common music file that has been compressed to hell, show up as if it could do with a healthy portion of amplification:
Waveform view.png (20.14 KiB) Viewed 1517 times
Waveform view (dB).png (17.01 KiB) Viewed 1517 times
Quite a difference isn't it?
I seem to remember this default was chosen to help beginners. I think it may mislead beginners and pro's...
waxcylinder
Post by waxcylinder » Tue Jul 28, 2015 6:21 pm
+1 to that
Gale Andrews wrote:How exactly do you want to implement it?
How about an extra button on the Zoom Toolbar - seems the appropriate place
Peter
Post by steve » Wed Jul 29, 2015 12:03 am
cyrano wrote: like having "waveform db" default and not the very misleading "waveform".
In their own way, both are "misleading".
This image gives the impression that the noise level at the start is about half as loud as the music:
This image looks like a sine wave:
as does this:
and this?
Misleading or revealing? It depends what you are looking for. ;)
Post by steve » Wed Jul 29, 2015 1:11 am
MichloIW wrote:Something I would find extremely useful for speeding up the editing process (and thus, hopefully others would) is the ability to snap back to the view setting we had after we "fit selection" or "fit project" or even, if possible, before we start zooming in.
I'm pretty sure that snapping back after "fit selection" or "fit project" could be done. Snapping back to "before we start zooming" could be problematic because zooming may be multiple events (for example, when zooming with the mouse wheel there is a sequence of small rotational movements). The difficulty is determining the point that the user wants to go back to. One possible solution could be to have a saved zoom level that the user can set at any time.
Post by Gale Andrews » Wed Jul 29, 2015 4:23 pm
cyrano wrote:Simply having a sensible default and going back to the same default when you "unzoom" (Zoom normal) would be a good start.
Audacity has Zoom Normal (CTRL + 2 or COMMAND + 2 on Mac).
But if your cursor was near the end of a long track, even if zoomed in no further than Zoom Normal, then you did Fit Project followed by Zoom Normal, the view position goes back to the start of the track. Let's take that case. What view and zoom position do you want to go back to after Fit Project?
cyrano wrote:Seems like a sort of "undo zoom" in stead of "go back to default".
You mean, so that the View > Zoom Normal level was customisable?
There is still the question of going back to the same view position or not.
Post by Gale Andrews » Wed Jul 29, 2015 4:35 pm
waxcylinder wrote:
+1 to that
What I meant was what Steve was asking. If we just do what amounts to "Undo Fit Selection" and "Undo Fit Project" and that only works if you don't zoom between "Fit" and "Undo Fit", that should be a simple enough concept - but not as useful as other solutions.
waxcylinder
Post by waxcylinder » Wed Jul 29, 2015 5:51 pm
What I think I'd really like is a user settable zoom level button where I could say be at my favoured zoom level at that time (normally my working zoom level is with 3 to minutes of audio on the screen) then press right click to store that zoom level with the button. Then subsequent left clicks of that button would return to me set zoom level.
I may just add this to the Zoom toolbar proposal in the Wiki :idea: :geek:
Update 18Aug15: I did just that - see: http://wiki.audacityteam.org/wiki/Propo ... om_Toolbar
Peter.
