I use to change the audio Host between MME, Wasapi and ASIO quite often, and one thing that bothers me is that I'm always needing to adjust the Latency correction individually (since each host has a different latency when recording).
I don't mind latency at all though.. the Latency correction Preference takes this problem away from me... ..but changing Hosts, always brings it back. Hosts and the Latency correction Preference seem very related to me, so maybe they could be linked together in the future?
By that I mean that, Latency correction adjustments would be saved separately for each Host (they could be all the same number initially, by default.. ..but once you change it, it could consider that a change only for the host currently being used).
I'm not sure if the whole "Recording" preferences page should be linked to the Hosts individually.. ..but the Latency correction Preference at least seems to make sense to me to be linked like so.
Thanks.
