Rapid Comparison Switching
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Post by kozikowski » Fri May 22, 2015 6:38 pm
I know this came up in the dim, dark past, but picture two slightly different tracks one above the other. I want to compare them by rapidly switching—one button—and not double SOLO-ing for example. I think it turned out there was an off-menu way to do that.
billw58
Re: Rapid Comparison Switching
Post by billw58 » Fri May 22, 2015 7:14 pm
Preferences > Tracks.
Solo button: Simple.
-- Bill
Post by kozikowski » Fri May 22, 2015 7:50 pm
So that would be no, then. Simple allows me to one-button switch between the single goal track and both. It also allows me to switch between the tracks: This SOLO button and That SOLO button and This SOLO button and That.
Two buttons.
waxcylinder
Post by waxcylinder » Sat May 23, 2015 10:50 am
kozikowski wrote:So that would be no, then. Simple allows me to one-button switch between the single goal track and both. It also allows me to switch between the tracks: This SOLO button and That SOLO button and This SOLO button and That.
Two buttons.
+1
I've always found this awkward - I want an instant switch comparison, never managed to achieve it as I fumble around with the existing TCP buttons
Peter
Post by steve » Sat May 23, 2015 11:56 am
waxcylinder wrote: I've always found this awkward - I want an instant switch comparison, never managed to achieve it as I fumble around with the existing TCP buttons
Set the "solo focused track" shortcut to something convenient (eg "Numpad 5")
Set Preferences > Tracks => Solo button: Simple.
Set Preferences > Tracks => Move track focus cycles repeatedly through tracks.
Then it's just:
5
down cursor
5
down
5
waxcylinder
Post by waxcylinder » Sat May 23, 2015 4:33 pm
Then it's just:
5
down cursor
5
down
5
And that's "discoverable" ... :? :roll:
But a useful tip nonetheless 8-)
Post by steve » Sat May 23, 2015 4:57 pm
waxcylinder wrote: And that's "discoverable" ... :? :roll:
Don't blame me :D - I've always said that I think the "simple" solo button behaviour should be the default. The custom keyboard shortcuts are just icing on the cake.
waxcylinder
Post by waxcylinder » Sun May 24, 2015 10:58 am
Don't blame me :D - I've always said ...
Hahahaha :lol:
Post by Gale Andrews » Sun May 24, 2015 1:30 pm
Yes I wanted "Simple" to be default too.
Post by steve » Sun May 24, 2015 2:10 pm
Would it be worth having an additional Solo button behaviour option?
  • None
  • Simple (like the current "Simple") [default]
  • Multi (like the current "Standard")
  • A/B
The A/B option would be for the specific case cited by Koz (which I think is a fairly common use case).
With the A/B option selected:
1) (ideally) the Solo button label would change to "Solo A/B" (not sure if that is possible).
2) If the track that has its button pressed is not soloed, clicking the solo button solos that track (unmuting if necessary). Only the soloed track plays.
3) If the track that has its button pressed is already soloed, clicking the (currently depressed) solo button, un-solos that track and soloes all other tracks.
4) If a track is muted and soloed, mute takes precedence. The purpose of this is that it allows A/B comparison of two tracks when there are more than 2 tracks in the project.
Example - A/B compare tracks 3 and 4 of a 4 track project:
  1. Select the "A/B" option for Solo button behaviour in Preferences > Tracks.
  2. Mute tracks 1 and 2 (so they will not play)
  3. Start playback, loop playback, quick-play or loop quick-play
    • Repeatedly click the solo button on track 3 OR
    • repeatedly click the solo button on track 4 OR
    • move focus to track 3 or 4 and use the keyboard shortcut to toggle the solo button.
